2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
No air bax for 2017 duallys?
Old 07-20-2018, 12:16 AM
bobv60's Avatar
bobv60
bobv60 is offline
I might buy a 2018 F450 platinum tomorrow, and looking for camper brackets and air bags. Looking on line it shows there are no air bags that fit the f450s. Is that correct?
Looks like there are some for non dually only
Old 07-20-2018, 07:51 AM
nuctrooper's Avatar
nuctrooper
nuctrooper is online now
5000 ultimates fit the 18 duallies. Several users on here reporting successful installs. Also, no issues with the torklift frame mounted tie downs. Etrailer.com has both.
Btw-the 450 is absolutely awesome with a TC loaded. You’re going to wonder how you hauled a TC without it...
Old 07-20-2018, 08:09 AM
2009kr's Avatar
2009kr
2009kr is offline
It possible that you won't need them. It takes 3000# to get mine to squat 2.5" and touch the helpers. According to the spring specs, it will take over 4000# to squat one more inch.
I figured I'd want airbags and was sure I wanted an aux tank in the bed when I bought my 2017 F450. Well, after driving 20000 miles I have neither, nor want them anymore.
Old 07-20-2018, 08:33 AM
blueglide's Avatar
blueglide
blueglide is offline
Doubt you'll need them. Put a set of Torklift upper and lower stableloads on and I bet you're fine. I carried an Arctic Fox 1150 TC in my 2015 F350 DRW gasser and the truck never knew it was there and they are heavy beasts. I'm towing a fiver now so haven't had a TC for awhile but the Torklift Fastguns are fantastic for tiedowns.
Old 07-20-2018, 10:41 AM
nuctrooper's Avatar
nuctrooper
Hauled my TC on the '17 450 without airbags, and subsequently with airbags. I personally prefer it with airbags, and run them about 80 psi.
Yes, the truck certainly handles a TC without airbags and drives just fine. I'm just not a fan of the squat when carrying a heavy TC, which put the nose level to slightly higher than the rear. Headlights in the sky blinding traffic (adjustable of course). Just looks like it is carrying a heavy load. With airbags, I maintain a level to 1" rake (rear higher), headlight angles change less between loaded and unloaded, and if you have a compressor, you can use the airbags to help level the camper. And when its not loaded, drop them to 0-5psi and you can't tell they are there. For me, I'm happy with my airbags. Again, though, they aren't required on a 350DRW or 450.
smlford
Slide-in / Truck Campers
05-25-2017 05:24 PM
cyncwby
6.7L Power Stroke Diesel
13
05-01-2016 01:36 PM
jel88
02-10-2014 04:21 PM
60RatRod
13
09-19-2010 09:18 PM
calf roper
18
12-22-2008 06:20 PM
Quick Reply: No air bax for 2017 duallys?
