2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
best year ford expedition 2007 to 2017
Old 07-13-2018, 07:36 PM
stupidgirl's Avatar
stupidgirl
stupidgirl is offline
what year is the best year ford expedition?
Old 07-15-2018, 07:51 PM
Matthew Gallagher's Avatar
Matthew Gallagher
Matthew Gallagher is offline
4wd Low
Depends on what you want... Ford continued to make improvements as years went on. So to most the 2017 would be “the best”. However that also means you get the EcoBoost motor.
More power. Supposedly better fuel economy. however some people are up in the air about long term reliability especially considering the twin turbos. Fuel economy real world isn’t that improved. No V8 burble...
I would have loved a newer truck but when I got mine but I was on a budget. Mine is a 2010 fully optioned out and I love it. I didn’t want anything older then 2009 as that’s when the 6 speed trans was introduced and the 5.4 got a power bump (to 310). 2010 was also when they introduced trailer sway control.
Old 07-17-2018, 05:50 PM
Henry Ford the 8th's Avatar
Henry Ford the 8th
Henry Ford the 8th is offline
2013 models came with Lear Car2U garage door openers in the visors. Looked just like the HomeLink units used in previous years but way underpowered. No range, barely worked, worthless. Ford switched back to HomeLink in 2014 and I ordered a 2015 visor to fix my '13.
Old 08-19-2018, 08:57 PM
dmpsix's Avatar
dmpsix
dmpsix is offline
You know what, I want to expand on this question.
I'm gonna be in the market whenever my 2003 5.4(2v) decides to die. Might be a while since it has 220k miles and ZERO issues.
when it does, I want another Expedition for sure..question is, what year? I love the 5.4 but I hate the 3v problems that a lot of earlier models like 04-09 had on here. Supposedly they fixed the issue in 08 on the f150 but there are still stories around.
I probably will aim at a 12+
budget is going to be under 20k, so I know ill be looking at higher mileage like 100k+
but what do you guys think?
Old 08-19-2018, 11:28 PM
Matthew Gallagher
4wd Low
This video shows the difference from the 04-08 trucks to the newer 2009 and up trucks, the spark plugs and heads were completely redesigned. And they are no longer an issue.
The 3V motors are still very particular about oil, needs to be changed often (every 5 k) this is imperative for the cams and phasers that control them.
Thw other benifit of 09 and up trucks is the transmission . The six speed alone is worth the premium. Stronger, more towing capacity, better fuel economy NO drawbacks.
johnkn
02-07-2012 03:12 PM
cjgeorge32
43
12-29-2011 01:36 AM
GlassLeather&Wood
20
11-10-2010 07:29 AM
John_2004_EB
1997-2006 Expedition & Navigator
12-17-2009 03:46 PM
brufener
06-01-2005 01:35 PM
Quick Reply: best year ford expedition 2007 to 2017
