2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
F350 SRW - Curb Weight
Old 07-11-2018, 10:28 PM
truck4andy's Avatar
truck4andy
truck4andy is offline
So I've been looking for a loaded F350 SRW 4x4 176" for a new 5th wheel I'm looking at but I'm running into a payload problem.
According to the web the payload should be 4,440 lbs but what I'm find in reality is far off.
Example today I contacted a dealer, the F350 had almost all options but the payload was only 3,089. That is a a major loss of payload.
http://www.windowsticker.forddirect....w0Q1o8usgOM%3D
I'm planing on having a tong weight from the 5th wheeler of ~2,900, 2 adults and your normal cab items for traveling with a 5th wheel. Based on this the 3,098 is way to low. I would be over with just me and the 5th wheel.
So I'm here hoping that I can some input on what other F350 6.7 SRW 4x4 176" are seeing for their payload. If this is the norm I'm going to have to ditch the SRW and go DRW.
Thanks for any input. I look forward to see what others F350 SRW owners are seeing on their tags.
Andy
Old 07-12-2018, 04:23 PM
svtride's Avatar
svtride
svtride is offline
Andy
Here's my door sticker image...lots more in the thread too..
https://www.ford-trucks.com/forums/1...l#post17688714
Old 07-12-2018, 04:28 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
The published payload is the most basic truck with little or no options, as options are added your payload goes down, And depends on what engine it has. the 6.7 lowers payload considerably.
Old 07-12-2018, 04:31 PM
toymaster's Avatar
toymaster
toymaster is offline
.... the F350 had almost all options but the payload was only 3,089....
Read the name of the list you are looking at. "Maximum payload" This is the absolute most you can get with the frame and suspension from a CC LWB F350. You have to deduct the weight of any and all options i.e. diesel motor (and all its trimmings) and every other option over a base XL truck. You said yourself the truck had "almost all options".
Just as an added note: Personally, I would have zero problems with a #3K tongue weight on the truck you have there. Your only a few hundred over.
Old 07-12-2018, 04:48 PM
River Wild's Avatar
River Wild
River Wild is offline
Yep...you want papered payload then you're looking at a low optioned gasser. See my signature.
Old 07-12-2018, 05:36 PM
PGas32's Avatar
PGas32
PGas32 is offline
If you're buying this to tow a fifth wheel with, just get a dually and be done with it. Worth the peace of mind
Old 07-12-2018, 05:48 PM
toymaster's Avatar
toymaster
Well, if we are giving advice now......just buy two trucks, one for a daily driver and one for a heavy hauler. Why not have two super dutys for twice the price. Let them eat cake, I say.
Old 07-12-2018, 06:24 PM
slapshot12's Avatar
slapshot12
slapshot12 is offline
My truck ( see sig) has a payload of 3447. It's a loaded Lariat. If you're towing a 5er, you'll want the diesel. It may be a hit in the CCC, but IMO, it's worth it.
Lariatdriver's Avatar
Lariatdriver
Lariatdriver is offline
Andy
Im in the same boat. My Ram 3500 had a GVWR of 12,300. My new F350 GVWR is 11,500. I have tongue weight of 2400#. My new truck weights 11,440 when towing the 5th wheel. It’s gonna take a lot of supervision to stay legal. For some reason the F350 is considerably heavier than published data. In short the Ford truck does not equal the Ram truck in towing capability. Let’s hope we see more truck in the future F350.
Old 07-12-2018, 07:29 PM
toymaster's Avatar
toymaster
^^^^ That reply is full of so much bull **** it is hard to know where to start.
Old 07-12-2018, 07:32 PM
2009kr's Avatar
2009kr
2009kr is offline
I was expecting Ford to stop getting beat by the Ram when the 2017 came out. Nope, still 800# GVWR less. I would have been tempted to get the Ram in a SRW instead of my F450 - it would be within its limits on my fifth wheel, where the Ford was not. One test drive of the Ram settled that one for me though
Old 07-12-2018, 07:41 PM
crewzer's Avatar
crewzer
crewzer is offline
Andy,
Take a look at the chart below... I suspect it contains more accurate and useful info. Make sure you also take a look at Note (2).
HTH,
Jim / crewzer
Old 07-12-2018, 07:45 PM
Lariatdriver
It would be hard for me to leave a SRW truck, Ford will change or lose sales, it’s that simple. I’d bet they’ll fix it.
Why would you have to buy a dually to tow a 12,000# 5th wheel?
Old 07-12-2018, 07:50 PM
vancouverbrian's Avatar
vancouverbrian
vancouverbrian is offline
The members who have replied are correct but there are a few other factors. Which model you get...I ordered the 11500lbs GVW model. With my options ordered, the ordered guide allowed that option. Otherwise it defaults to the 11400lb GVW. It is possible to buy a downrated model of 10000lb GVW for those that want to pay less in registration fees in some states. Then the options on the truck you ordered have a bearing on payload. But what you do, is take the truck with full fuel tank, and the passengers and things you want to carry in the truck and drive over a scale. I took my 11500lb GVW and did this and it was 7568lb and you subtract the 2 numbers and it gave me an actual payload of 3932lbs. It is a Lariat cclb gas. I hope this helps. BTW...the guide is just that...a guide not the law. Actual numbers is what is real.
Old 07-12-2018, 08:02 PM
Screamingbear's Avatar
Screamingbear
Screamingbear is offline
Options are heavy.
See attached for the payload sticker on my 6.2 Lariat Value Package CCLB.
The diesel version of the same truck would lower the payload by about 750 pounds.
Quick Reply: F350 SRW - Curb Weight
