1985 e350 Econoline - HVAC Problems
Hello Everyone - hope you can help me out
I have older 1985 Econoline with 6.9 Diesel.
The HVAC fan seems ONLY to work on AC, when I switch it to heater or defrost, the 3spd fan turns off. Fan works fine on the AC.
It WAS working on defrost/heat until I switched it over to AC.
As far as I can tell this is all cable driven. I think the plenum door changes OK, but cant verify without the fan working.
I am unable to find any diagrams, reference info - does anyone have diagrams on this damn plenum or an idea why the fan would turn off?
I did notice the slider control has a fan switch control on it - switch depresses on AC position, but not on heat or defrost.
Appreciate the help!
Problem fixed.
DIAGNOSIS
- Found that engine side (heater) fan not working on defrost/heat. There is an inside fan which runs when on AC - that works OK.
- wired fan motor direct - worked.
- used multimeter - found no power coming on to the engine side fan at the plug
- traced back to the heater control - found power at the plug at the HVAC control module.
- Cut and replaced the wire from the plug to the other plug, used but connectors and shrikwrap tubing to seal it up. NOTE: I drilled a hole passenger side through firewall and put in grommet for running new line (as per below)
- Wire was cut where it went in through the firewall beside the heater hose.
- now working
NOTE: When hvac unit on AC, the inner fan works and the engine side is disabled. The engine side works when the hvac unit is on DEFROST or HEAT.
ALSO,
Had a problem with the HEAT/COLD damper door slider cable - the cable clip broke at the HVAC unit.
Used a plastic tie and a hose clamp around the cable sheath to hold - managed to pull the cable in tight to the swing arm without a problem. Finding a cable at wreckers or ordering one - good luck
There you have it - in case you have this proiblem...
DIAGNOSIS
- now working
ALSO,
Problem fixed.
DIAGNOSIS
- now working
ALSO,
DIAGNOSIS
- now working
ALSO,
From what I can tell the fan speed selector runs a loom to the fan motors resistor. One of those wires from the fan speed selector runs to a ground. I thought it was the green and white coming to the other side of the climate control but it either is not it or the climate control center is bad.
Thanks...
bowmanss
04-03-2018 07:22 AM
oldschool84f150
61
06-11-2011 02:52 PM
