Has anyone here ever successfully disassembled a 40/20/40 center console?
Ok, now that there are some pictures to use a reference, the storage compartment is made up of four sub sections: the main lower(bottom) storage cubby, The Bezel, The Lid, and The Cup holder.
First remove the two hinge pins holding the Lid to the Lower section. Theses pins look just like two aluminum nails with a slight bend. the pins will just slide out by moving I them toward each other (inward). As you can see my lid underside is missing the felt (plan to resolve this after cleaning) I did fully disassemble the Lid as well. Probably the highest chance of breakage separating the two Lid halves. Take your time, make sure the Lid is warm I stuck mine in the microwave for a few seconds. Once you separate the halves there is a spring and the latch lever inside. The Lid is easy to separate, careful on the spring, and easy to reassemble as well. Next is the main lower cubby section. You'll see several staple in the fabric get something flat and stiff (screw driver worked for me) and pry all the staples out, double check and get the all otherwise you may tear your fabric. Next drill out the four rivets, then remove the main lower section. OOPS... first you must separate the Bezel from the main lower section. Just use the same flat screw drive and go along the seam and pry the Bezel upward, there is an adhesive but its more like chewing gum than glue. Once you have Bezel off you'll see the staples (sorry, it's late and I'm tired) The cup holder can be pried off easily at this point, it's two piece and no fasteners are used.
Hope this makes sense and helps everyone out.
Here you go Brad. Removing the main surround bezel was probably the easiest part of this...aside from pulling the lid hinge pins.
I didn't count the alignment pins but none of them broke during removal. Just waiting on the felt sheets to arrive from Amazon in a couple days and I'll get it all reassembled and back in my truck. I'm thinking about selling the Jump seat assembly and trying to install a console from a newer series truck, I like the one from my 2003 F150 better.
#28
Well Brad, you're wrong. I took this unit apart and whether you want to believe me or not, nothing broke. Unless this storage unit was removed at some point in the past and reassembled, which I highly doubt given there are no signs of such. I've only owned the truck for about 3 weeks now.
In any case; to all of you interested in taking yours apart for cleaning or whatever, feel free to ask any questions. Regardless if some pins broke or not (they didn't) this is a relatively simple procedure to do.
#29
#30
@ Diesel Brad, my apologies, I took a closer look a few minutes ago in better lighting and yes there are molded alignment pin around the perimeter of the upper bezel piece, and some of those pins are broken or have been cut/snipped somehow. Mine did not have any clips on the pins, and was not separating in anyway prior to removal.
For those of you still wanting to take your storage units apart I say go ahead... you may encounter a different issue when removing the Bezel than I did. take your time and don't try this when the plastic is cold.
