1964 F350 Rear End Swap
Hello, it's me again. After several months on the back burner this project is coming back around. I ordered what I thought was the correct Dana 70 ring and pinion gear set from Summit. When my dad went to install it, the ring gear was about 1/8" thicker than the old one. Pictured are the numbers found on the old gear and the new one. Here is a link to the Summit product I ordered: https://www.summitracing.com/parts/sdh-706999-4x
Can anyone spot an obvious mistake? Can anyone identify the old ring gear by the numbers?
Any help is greatly appreciated! Thank you in advance.
Ring gear: 31711 // Pinion gear: 34550 =C7TZ-4209-B .. Ring & Pinion Kit 4.10-1 .. Parts list #'s 176 & 177 = 1967/77 F350 Dana 70.
Ring gear: 34840 // Pinion gear: 34550 = D8TZ-4209-C .. Ring & Pinion Kit 4.10-1 .. Parts list #'s 176 & 177 = 1978/79 F350 Dana 70.
JKessler00
12-28-2011 02:58 PM
RacerCoast
11-20-2009 09:42 AM
rsalter66
09-12-2007 07:42 PM
