302 0 Psi Oil pressure at hot idle.
Hello,
Recently acquired a 74 F-100 It was sitting for the best part of 8 years. With 180,000 miles on it, the engine runs great with plenty of power and no noise. Smooth like a sewing machine, but noticed the dash gauge read good oil pressure until warm and the needle would peg to the N of normal.
So I installed a mechanical gauge and it reads as so, 40-50 psi idle and drive when started and falls to 30-40 cruising hot and 0 psi at hot idle in gear. Bumps up to about 20 when parked.
No noise, no smoke, no problems.
Could there be something other than wear causing this? Bad oil pump, galley plugs, etc....?
If it does start knocking, that'll be the #4 & 8 rod bearings going south. Those are the last in the oiling system, furthest from the pump. I wouldn't worry too much, long as you have at least 40 psi up off of idle.
If you want to save what's left you could drop the oil pan and change the oil pump. Swap it out for a high volume, high pressure pump,. If you can't find one in both specs, get a high volume unit. Might also try first, changing oil to 20w50 and adding a bottle of STP oil treatment. Then see if the pressure improves before changing the pump
jas88
08-14-2018 07:14 AM
mvvette97
12-01-2008 10:51 AM
sjser
11-07-2005 03:55 PM
eandaauto
08-12-2004 09:34 PM
