Top of the morning to you March BS
#228
I should be around sat.
#229
Just as I'm beginning to see the finish line, the bearings on my die grinder are dying. It's only about 18-20 years old and was a low end unit to begin with so I guess I shouldn't really be surprised.
#230
#231
Yeah, that's probably where the next one will come from.
Lifted the smoke chamber off the frame so I could box off the open square tubing ends and started in on the firebox support...
I've got to slow down a little because I'm on my last roll of flux core wire. It's Harbor Freight brand and doesn't weld too bad once you figure out which settings it likes. I've got a 10 lb. roll of wire ordered which should be here next week some time. I found it for the same price as 2 - 2 lb. rolls locally.
#233
I tried my first weld today. Just practicing. I need to study up on it more.
How much should you be able to see when welding? I couldn't see my seam to make sure I was in the right spot. I was just butting up two flat pieces.
Edit: After a little googling, I need to mess with my auto darkening settings and maybe have more lite on my work. Still open for tips.
We also had a guy in the 48-56 forum that had a thread on welding:
https://www.ford-trucks.com/forums/1...-practice.html
I need to study that more....
Oh, by the way. I got my 6V tach wired up today. Need to mount it next and test drive.
It's the little things for me. I had to wait about 2 months after ordering to get this tach. Problems with staying 6 volt.
#234
Evening All!
Well, I got the rear springs modified the way I want to and they're mounted on the spring perches. Now all I have to do is cut the old spring hangers out of the truck and make the new ones. I hope to have the drop box here in the beginning of the week. Next weekend I have to go back up to St. Louis and help Mark with his trailer again. There's a lot going on and not much time to get it all done in.
#235
Morning guys. Time to head back to work...
#238
Evening All!
Dave. I can't wait to see the smoker done.It looks like it's coming together nicely.
I cut the hind legs off of Earthquake today. Getting ready for new suspension. I hope to have the majority of it done tomorrow. I don't like leaving the truck on jack stands. I was right. With the new axles and rear suspension, it got about 4" taller.
#239
I can't wait either, but have to work around everything else going on & the weather.
If EQ gets any higher, you're going to need blinking warning lights for low flying aircraft.
#240
sounds like you are moving right along alan.. i wish i was able to get up there and check it out.... have i told anyone that i am BORED to death...... but i think i am improving everyday
