Rear valve cover bolt removal 4.9
The rear bolt on the valve cover nearest firewall is impossible to see. Does anyone have a trick or technique for getting it out. I finally got my old *** in the engine bay and still having trouble. There seems to be a bracket or something on a stud where the bolt hole is and I'm not sure there is even a bolt on it. Any tips to get me going again or what the bracket thing is? Of course it is the last thing holding me up to put a new gasket on. Thanks Sandy
That's funny Eric. I thought of the same exact thing. Being old and 6'1" I don't fit in the bay well at all. Plus I screwed my back up on a jump years ago and bending over in there quickly reminds me I'm not 18 any more. Plus I found that the hood latch tries to get a little to friendly sometimes
I also being in my late 60's and having a back injury need a few aids, one of these is handy as well, just remember to tie it to the bumper or something so it doesn't slide away.
One more thing that can be done is take the front wheels off and set it on some short blocks. Cuts the strain of reaching to the back of the engine bay. I was doing a valve spring swap, so I was in there for a day or 2.
Good idea Eric. Thanks. Here is a picture of the culprit. It is a Valve cover bolt stud. It had the bracket on top blocking access to the bolt. The bracket was held on by a round star clip that is now destroyed on purpose. Anyway I just wanted you guys to know that I'm not totally crazy. Feeling it without seeing it or feeling the bolt was getting me very frustrated. It's off so now to getting it back on the road. Thanks guys Sandy
That bracket originally had a plastic clip that holds the fuel lines and the vacuum lines that run behind the cover, then under the intake manifold up to the front of the engine.
I use long needle-nose pliers to lift it off the stud, then a gear wrench on the stud to get it off.
It's incredibly easy to get to if the transmission isn't in the way.
Same problem
