Transmsion
Transmsion
I found 73 F100 360 automatic 4x4 i would like to use as parts truck for the conversion on my 75 F250 4x4 manual/ divorced transfer case. It looks like i can bolt it right up with minimal fab work. If you guys think it will work i plan on taking out the automatic/transfer case in F100 and dumping my manual/divorced transfer case in the Highboy.
My question is there a difference in transmissions used on 1/2 ton verses 3/4 ton trucks? A C4 is C4 should work on my F250 behind the 428 i have bolted in? Correct?
Just use the correct flexplate. That is where the balancing was controlled by the factory. It will have a specific weight welded to it that most FE flexplates won't have.
You can tell the flywheel because on the back side it will have a large piece of pie showing(that is the added weight cast into it).
Flywheel:
Flexplate:
Flywheel:
Flexplate:
Thank for reply.
After pricing different options. I’m leaning toward NV 4500. If I stay with divorced transfer case I don’t have to worry about the speedometer since it’s cable connected to transfer case.
The only problem I need to work out is how and what brand of hydraulic clutch setup I’m need? Anyonyone done a hydraulic setup for FE bellhousing?
Shadetree Mechanic10
02-10-2014 07:54 PM
offroad8072
09-22-2009 04:05 PM
Broke_Okie
11-29-2006 09:14 PM
FordPickup460
05-02-2005 05:28 PM
johnwhipple
10-15-2002 08:34 PM
