1994 B2300 Start issue... Please Help
#76
My initial fuel pressure test readings was incorrect. It was caused by the broken fuel valve at the raid. After I replaced the stem, it started reading some meaningful PSI when I primed the fuel system - key ON, like 35-40 PSI for a second. It would not HOLD the pressure like you said, it dropped pretty quick. When truck was running, the PSI stayed around 35 PSI.
When the car would not start, the pressure still showed 35 PSI when priming.
#77
#79
Wimpy spark = hard start.
#80
#81
#82
#83
Pawpaw,
Just a thought, remember one time I connected the gauge directly to the output of the fuel filter, no FPR, injectors, fuel raid (I know you have already warned me not to do do this). However, I learned something from it ... I remember the pressure shot up real high when I turned the key ON, and it dropped back to zero quickly. If the check valve in the pump worked, it should at least held it at certain PSI, but not zero.
In addition, if I have bad injectors (let's say), the pressure will not drop that quick, from 35 PSI to zero once priming is done.
I think I have a defective pump.
Any thought?
Any thought?
#84
Pawpaw,
Any thought?
Any thought?
#85
#86
Sorry I was out of town for the last 2 weeks and did not have a chance to work on the truck.
Anyway, I re-examined the fuel pump again by sliding the bed down a little to gain access to the pump. Took the pump out and applied 12V, it ran fine. Tried to blow air into the pump's output and it's blocked, I assumed the check valve is good. I also removed the intake manifold (upper) to get ready to replace the fuel injectors. Removing the intake manifold was easier than I thought, maybe 30 mins or so. Will let you know what will happen after replacing the injectors. The parts should be here by Tue.
#87
#88
#89
#90
