1989 Bronco rear seat
I need some info on 1989 Bronco rear seat. Are they at all similar to a standard cab bench seat, slide, tilt etc.? Or are they solid mounted with a solid back?
I need a new bench seat for my 1989 F 250 std. cab and found a nice Bronco rear seat in the right color for a great price on CR but don't know if it is even use-able.
Any info appreciated!
They are spring loaded too and flip forward.
When folded, they tuck completely into the area behind the front seats and the ledge in the floor and kind of form a bulkhead.
(Just about every Bronco rear seat I have seen , the upholstery is unhooked at lower front edge and the torsion spring isn't installed correctly like in the above picture.)
