CRISIS! 1990 Bronco needs starting!
ok, just a note, if you are running the engine to fully warmed up; The G/Y wire powers up the O2 sensor heater circuit. So without the G/Y you might run rich at idle. You can hook it up to the other Yellow wire if you are working on the engine.
Not a big deal.
The EECM ignores the O2 sensor at cold start-up until the ECT- Engine Coolant Temperature sensor tells the EECM that the engine is warmed up (first 2 minutes or so).
Not a big deal.
Welp... she fired right up. Then she started smellin real bad, rich like you said. THEN the Anti-Lock light came up! Now it won’t go away. And when I throttle it there’s a wee shriek. Ah I’ll sleep on it and try to figure it out tomorra. Thanks for your help this late evening sir! Mucho appreciated!
Not knowing what you are trying to accomplish;
With the exception of the Red/Light Blue, you can connect all the wires together if you want everything to work. Spread the load between the 2 Yellows;
Red/Light Blue – use only to energize the starter solenoid.
No need to connect this one for now;
Brown/Pink - same as R/LG in Start Position
FYI;
Yellows – 12 volts from Fusible Link
Red/Light Blue - Starter Solenoid - momentary contact
Red/Light Green - Power to Coil/TFI/EEC Relay
Black/Light Green – Wipers/Windows, Brake Anti-Lock etc.
Gray/White – A/C - Heater, etc.
Purple/White - Instrument Cluster
Brown/Pink - same as R/LG in Start Position (not Brown/Pink)
FYI;
Black/Pink - same as R/LG in Start Position (not Brown/Pink)
FYI;
FYI;
Hey again. Now the fuel pump won’t pressurize, can’t hear it do its thing. Truck won’t start. Hotwiring it won’t do the job. Know where I can buy a new harness as shown in the first post? All these are too short, cut and I need the wedge
