Left rear brake sticking
Old 12-14-2017, 12:01 PM
HighPlainsRichard's Avatar
HighPlainsRichard
HighPlainsRichard is offline
4wd Low
Hi All,
I'm kinda new here, but used to be on the old FTE listserve. Anyway, my beast is having a problem. This is an '84 F250. My left rear brake is sticking. It will roll on dry pavement but gets hot pretty quick. I've checked some of the other threads on this but hoped I could isolate the problem a bit more before I tear into it (particularly because it's snowing and I don't have a garage). So I thought I would include a few more details. The right rear wheel turns freely. Also, the emergency brake is topped out. As in, I can only push it down about 1/2 an inch. So, I'm thinking that the left side emergency brake is fully engaged. It has slowly tightened up over the last 4 months. Any thoughts on what is going on? I have a few ideas, but was hoping somebody has had past experience with this.
HighPlainsRichard
'84 F250, 460, C6
Old 12-14-2017, 12:10 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,708 Likes on 1,381 Posts
The emergency brake cables rusting up and sticking is a common problem. The rear portion that is in the sheath gets froze up.
If you want to get by for now, get some vise grips and squeeze the left cable tight about 1/4 inch ahead of were it goes into the sheath, this is about midway down the outside of the frame on the driver's side. Once you get the vise grips on it, take a hammer and hit the side of the vise grips to drive the cable back up in the sheath. If it moves 1/4 inch, then re-grip the cable again and drive it back some more. Once you get it driven back, the brake should release. Then do not use the parking brake till you get it fixed. If you forget and use the brake, then it will pull the cable again and lock the brake up again.
The parts stores used to keep these in stock and they are fairly reasonably priced. It's a very common problem on these trucks.
Old 12-14-2017, 12:24 PM
HighPlainsRichard
4wd Low
Thank you. I will give that a try.
Old 12-15-2017, 11:57 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,143 Likes on 1,822 Posts
I would get both new cables, wheel cylinders and shoes and replace them.
The cables because frozen, shoes because the 1 side was hanging up and over heated that set.
cylinders because you are there and how old are they?
Last might be a hardware kit for both sides. It is all the springs, adjusting cables are extra, but the springs get weak over time with heating and cooling but that's your call.
Dave - - - -
Old 12-16-2017, 04:25 PM
HighPlainsRichard
4wd Low
Well, that worked and the wheel is rolling free now. I replaced the brakes about 6 months ago since I was in there putting in new bearings. Looks like I might be getting new cables and hardware for Christmas.
makthenif
1997 - 2003 F150
12-27-2015 10:01 AM
mike L
04-02-2015 09:25 AM
bad_habit59
02-12-2009 12:20 PM
truszip
07-19-2007 11:24 PM
herbray
Aerostar
40
11-06-2005 11:49 AM
Quick Reply: Left rear brake sticking
