jag irs rear
jag irs rear
Looking forward to starting the next truck (56), I have been contemplating what rear suspension to use.. 9in, another 8.8 or maybe a jag IRS..
I see a lot of discussion on the jag front end pre-53.., not much on the rear.
one is available near me, what should I be looking for? (seemingly from an 85).
Sam
Sam
Sam
Sam
Below is info from a post a long time ago by "halfdone"
"Jag centres are basically a Dana 44, so power handling is similar.
What kills most Jag centres is inadequate mountings or control arms. If it moves around under hard acceleration it won't last long. Another good reason to retain the cage if you can.
Like any diff, it will last longer behind an Auto than a Manual, and will last longer with less shock loading. Backing off after a burnout is the big killer of diffs at the drags, not hard launches.
Texan: Ask him to pay for the trailer hire . I did that to a guy once...he had a 48 Ute that my ex wanted. He was asking $500, so I offered $100. He said NO. About 6 months later he rang and said "I'm moving this weekend, you can have it for $100" I replied "I'm broke this fortnight, but I'll take it for nothing" He said YES.....so I said "and you'll have to pay for the trailer hire".........he thought for a minute and said "......you OWN the trailer Mark" "......OH YEAH, I FORGOT" ....only thing better than free parts is being paid to take them....
I would use the Jag rear in preference to an original, but as Mike Bishop said you need a strong chassis for all independent. Boxing probably isn't enough. An X member or double K member is needed. Both are easy to do in 2 x 1 tube. My rule would be "If you don't have the skills to box a chassis and do an X member....you shouldn't try doing a Jag rear"
Sam, The jag IRS is definitely sexy but certainly not simple and to my way of thinking not that significant a handling advantage. That is why I went Jag IFS and 9 inch rear on Willard, my 49. Just my $.02, the real advantage is in the IFS.
Sam, this is my plan after I retire mid year. Team321 LLC Ford Truck Independent Rear Suspension (321)960-5945 dheld@cfl.rr.com Joe
I have posted a few times on the Jag Rear, as i am using one in my 56. The following is what I posted regarding which years etc are the best to use:
https://www.ford-trucks.com/forums/7...irs-specs.html
I would agree that it works best with the chassis stiffened at least in the immediate area, but prefferably front to back if going independent at the front too (as I have done).
It is not as hard an install as you may think, and you can make it look nice too with a little effort.
Here is what my rear end looks like so far (Still yet to complete piping the brakes up etc.)
Cheers
Lee
Cheers
Lee
We are installing the Jag IRS like this...
Here are a couple of photos of the install I'm doing on my dad's '56. I have boxed the frame rails and we added pinion supports for torsional stability. The goal is for improving the ride through the canyons and backroads.
Crossmember is tacked in place.
Front view with upper pinion supports disconnected. Notice the upper mounting tabs welded to the frame boxing plates.
The shocks and springs temporarily installed. Because of the increased angle of the shocks mounting position we are able to use much lighter springs than normally necessary which improves the ride.
Next we will be building wheel tubs for the 275-18 wheels/tire combo and adding a fuel tank.
