1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Full rear spring packs to replace blocks, 08+
Old 11-24-2017, 10:00 AM
speedfreak78's Avatar
speedfreak78
speedfreak78 is offline
What, quality, full rear spring packs are people using to repace the blocks on 08+? I'm planning on calling Deaver and Alcon to see what custom springs would cost but wanted to see what was available off the shelf. Only thing I've seen that looked decent were the Icon springs in 5". Rough country/skyjacker aren't options, I want something that rides well.
Old 11-24-2017, 11:19 AM
redford's Avatar
redford
redford is offline
Received 1,582 Likes on 922 Posts
Most cities will have a local spring shop that will gladly make you exactly what you want. I would encourage you to start your search locally first.
Discuss ride height, load carrying capability and empty ride harshness with them. They will probably surprise you.
Old 11-28-2017, 09:21 AM
speedfreak78
No one has done a full spring lift on one of these things?
Old 11-28-2017, 10:55 AM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
I agree with Redford. Plus you don't have to pay shipping.
Old 12-07-2017, 10:01 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
Add traction bars from OUO or PMF, a high arch spring will ride like crap and wont flex due to not enough movement from the rear swing shackle
Old 12-08-2017, 07:27 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
Received 1,008 Likes on 776 Posts
maybe some sulastic add ons would do the trick
Old 12-08-2017, 09:35 AM
speedfreak78
I wouldn't consider a 3-5" over stock arch a high arch spring, at least not on these trucks with a 66"+ long spring. I'm only here trying to figure if there's an off the shelf spring people prefer for the 08 and up trucks before I go calling around for custom springs. Doesn't seem like many people do full spring lifts, just bigger blocks or add a leafs. I'll be using them in a custom application where stock shackles won't be a limiting factor.
Crewcab Turbo
11-28-2011 12:02 PM
Csticks
16
02-23-2011 03:22 PM
deveaum
09-24-2009 08:49 AM
250-highboy-76
02-18-2004 11:53 AM
Biggie
10-27-2003 07:53 AM
Quick Reply: Full rear spring packs to replace blocks, 08+
