The NJ November Turkey BS Thread
#241
#243
Received 3,113 Likes
on
blahhhh. started today by bursting the lower rad hose on the Kenworth at 6:30 am with a full load of asphalt in the box..... on the road.....
#247
#248
on
no it was not Neil. to make matters worse it was NY state 6F. if you know state law
(and i am sure you do) you only have one hour after it goes into the truck to put it down, and it has to be at least 300 degrees to go down. lucky for me i was rite outside the jobsite when the hose went and i was able to get the load off.
the guy i was working for had a length of 2 1/2 hose in the service truck so i had it up and running again about 45 minutes later. only real issue was had to drive 1/2 mile with almost empty radiator to get to the water wagon to fill it up.
then i had to drain it and fill the rad with antifreeze when i got home at the end of the day.
but that set the mood for how the rest of the day went.
the other truck hooked a piece of buried chain link fence with the air tank drain and ripped it off. and the boss was out on a different job and the excavator died, and it took him most of the rest of the day to get it running again. so all three of us had a crappy days
#249
#251
#253
Good evening from West Virginia and I hope everyone had a great Sunday. It has been some time I last dropped by the NJ chapter and thought it was time to drop in again.
I had family stations at McGuire and made many friends there at the time. I still follow some. Then I became acquainted with several NJ members. I miss my trips there and always had a great time and most were very friendly. NOTE: no one was ever unfriendly just less personable!
Rod
Rod
#254
tiny1, You would stop by the WV chapter from time to time. Drop in again sometime. I am working on getting more activity going again.
Rod
Rod
