2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Tailgate Light Bar
Old 10-26-2017, 01:19 PM
Chase4R's Avatar
Chase4R
Chase4R is offline
Tailgate Light Bar
New here, new to ford, and new to an F250. Was wondering if anyone has installed a tailgate light bar on the 17 models? Any info on installation, brand preference, or just pictures of finished product would be great! Thanks!
Old 10-26-2017, 01:47 PM
Slavoise's Avatar
Slavoise
Slavoise is offline
I just installed the DRW OEM under tailgate light. I wired mine so that it isn't constantly on like the DRW but so that it is an actual extra brake light.
Old 10-26-2017, 02:02 PM
Chase4R's Avatar
Chase4R
Chase4R is offline
Interesting, what did you wire the tailgate light into? Do you have any pics?
Old 10-26-2017, 02:05 PM
Slavoise's Avatar
Slavoise
Slavoise is offline
I'll take some pictures this weekend. I first tried wiring it into the trailer plug... Bad idea... The truck thought a trailer was plugged in every time lol. I needed up running wires to the tail light and used posi-tap to get to the brake lights.
Old 10-26-2017, 02:24 PM
Chase4R's Avatar
Chase4R
Chase4R is offline
Great, thanks. But dang.... lol I was hoping I could get by with wiring it into the 4 pin but it sounds like that won't work.
Old 10-27-2017, 08:07 PM
NorEasterMA's Avatar
NorEasterMA
NorEasterMA is offline
Can you let me know the part number for this? Looking to grab one. Thanks!
Old 10-27-2017, 08:10 PM
oscard0215's Avatar
oscard0215
oscard0215 is offline
HC3Z-13A613-B
8U2Z-14S411-AAC
part # 's.. these are the ones i used.
Old 10-27-2017, 09:05 PM
NorEasterMA
Thank you! Ordered from Tasca!
Old 10-27-2017, 09:15 PM
KWDAILYD's Avatar
KWDAILYD
KWDAILYD is offline
I also installed the OEM light bar on my F350 SRW. I wired mine to the passenger tailight so it is on when the lights are on.
Old 10-27-2017, 09:19 PM
Chase4R's Avatar
Chase4R
Chase4R is offline
Truck looks good! Any pictures or info of the actual wiring process? Wondering if the same process will work for the 60" light bars.
Old 10-27-2017, 09:36 PM
KWDAILYD's Avatar
KWDAILYD
KWDAILYD is offline
No pictures. The 3 Raptor lights in the grill are wired to a key on hot under the hood in the upfitter bundle, solid brown wire I believe. That way they are used as daytime running lights also.
The side marker lights on the running board brackets and the rear light bar are all wired into the passenger tail light. They are all on when the lights are on.
Wish I could find two more running board brackets to fill in the gap and add another light on each side so the spacing would be equal
Old 10-27-2017, 09:37 PM
NorEasterMA
See I wasn't sure how the 3 running lights on each side would like with the supports not being evenly spaced...I had just planned on putting one on the front and rear support and skipping the middle...but it doesn't look bad! Time to rethink.
Old 10-27-2017, 09:43 PM
Chase4R's Avatar
Chase4R
Chase4R is offline
Hard to tell in pictures what brackets you have, but I know you can find individual brackets on amazon. Could also buy from dealer but risk paying an arm and a leg. Thanks for the info on wiring!
Old 10-27-2017, 09:44 PM
KWDAILYD's Avatar
KWDAILYD
KWDAILYD is offline
I have read somewhere on one of the 6.7 sites where guys are buying the brackets that fit the F150 because they are shorter and the raise the running boards up. Some has to have some of the longer brackets laying around. I measured and the spacing would be equal to add another bracket.
Old 10-27-2017, 09:50 PM
KWDAILYD's Avatar
KWDAILYD
KWDAILYD is offline
I got the LED lights on Ebay. They are cheap lights from China. They are suppose to be water proof and We've pulled our trailer through a couple of pretty good down pours along with local driving in the rain and so far so good.
They were a package of 10 for about $8.69 delivered.
Quick Reply: Tailgate Light Bar
