New 5th Wheel, B&W turnover ball in truck bed already
Is the truck a short bed? Sounds so. IF, you have a fifth wheel that is newer than '10 year models, all you need is the standard Companion. The reason for this is that the corners of the camper are 'clipped' or rounded to avoid hitting the cab. This statement will be judged by others, but if you set your hitch up in the rearward setting, the coach will not hit the truck. I've done several this way. Some will say that the weight will be rear of the axle, well, look at where the main Turnover Ball is attached. Most of the weight is there and has very little impact on the setup. Three trucks that camp with us once a month are all short beds with B&W Companion hitches with fifth wheels and have had no problems.
Well, I already have the B&W gooseneck ball hitch installed in the truck, removing it and installing the ford factory hitch would not be an option.
It looks like either a B&W companion (slider or non-slider) is my only option right now.
It is a SB truck and the trailer is a 2017 Keystone Sprinter 37' and it does have rounded front.
The companions are kinda spendy, I'd shop around, check E-Trailer, etc. I can't help you on slider recommendation or not. Mine's a long bed, and I'm using a standard Companion hitch in mine (which I'm very happy with). I got my Turnover Ball/Companion combo thrown in when I worked the deal for our new 5er last spring.
Also, remember to grease the jaws of the head with a good bearing grease from time to time. Doesn't matter if it's red or black grease. Oh, and get you a good torque wrench that goes to 250 ft. lbs. Lowe's has good ones for around $75 in the Kobalt brand. They are great for not only your hitch, but also the lugs on the camper.
While you have already ordered the Companion, I went the other direction. I replaced the pin box on my Cardinal with a Reese Goose Box. It uses the existing B&W Turnover Ball in my truck without having to mess with installation/removal of the Companion. I have the bed free at all times.
I even installed it myself. The nice thing about using the truck bed and the RV landing gear as helpers was that no one told me I was doing it wrong...
I have a ? that kinda goes along w/ this. I have someone that is going to give me a 5th wheel hitch. I just need to get the mounting brackets for it. When I looked them up I keep get this "will not fit cab & chassis". Could someone tale me what this means or a set of brackets that will fit a 04 crew cab F350.
If you have a pick-up box, you do NOT have a "cab and chassis" truck.
If you have an aftermarket utility box, and the frame rails are not arched over the axle, you DO have a cab and chassis.
"Cab and chassis" trucks are sold as "incomplete" vehicles the people buy to mount a utility, dump box, flatbed or some other type of work body on and have no reason to buy a vehicle with the pickup box onit.
If it has a pickup box on it, the odds are REAL LONG that you do NOT have a "Cab and Chassis" because the frame rails on the C&C are a different width than the frame rail on a pickup, so it would be a major job to convert a C&C to a pickup. My guess is you are good to go with the hitch. The difference in width is the main reason nthe hitch does "not fit cab and chassis". Best of luck to you!!
