Best Towing Mirrors For A 1995 F350?
Old 10-19-2017, 04:45 PM
BreakAes's Avatar
BreakAes
BreakAes is offline
I did some research awhile ago and it seems the top choices for towing mirrors are the Grand Aero 3, and the McKesh towing mirrors. I was leaning towards getting the Grand Aero 3s.
I have a 1995 F350, so I don't think I can install OEM towing mirrors. Is that correct?
Let me know if you have thoughts on what the best towing mirrors are.
Thanks
Old 10-19-2017, 06:28 PM
mrollings53's Avatar
mrollings53
mrollings53 is offline
I'll pass on both, and install some west coast style mirror like mirror 2 or 3 below.
Old 10-19-2017, 06:31 PM
BreakAes's Avatar
BreakAes
BreakAes is offline
Thanks, where can I get those?
Old 10-19-2017, 06:54 PM
FordTruckfan89's Avatar
FordTruckfan89
FordTruckfan89 is offline
What many guys do, is use the swing lock 2 point mirror arms and use the larger gooseneck style mirror heads, I love mine
Old 10-19-2017, 08:15 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Mrollings53 chart type 8 OEM towing mirror
Old 10-19-2017, 09:32 PM
humphrey169's Avatar
humphrey169
humphrey169 is offline
I want to see the number 12 on a truck
Old 10-19-2017, 10:31 PM
BreakAes's Avatar
BreakAes
BreakAes is offline
So where is the best place to buy these kinds of mirrors?
Old 10-20-2017, 06:20 AM
Diesel_Brad
1997 Ford F750, Salem OR - 121872756 - CommercialTruckTrader.com
Old 10-20-2017, 06:21 AM
Diesel_Brad
The Junk yard , Craigslist
Old 10-20-2017, 07:40 AM
humphrey169
That didn't work. Unless you have to sign up
Old 10-20-2017, 08:03 AM
wharthog's Avatar
wharthog
wharthog is offline
mounting mirrors
Is there a diagram or measurement as to where the lower holes are to be drilled when using the mirrors in this pic? I have a set and would like to use them but the way they lay when checking from side to side is different so one of the set of arms is tweaked a bit. I know I could go to a salvage yard to find some on a truck and measure them, but if there is a spec, I would rather have that. They are great because they can flip in and out for clearance.
Old 10-20-2017, 06:15 PM
Diesel_Brad
The 2 top holes are already there(if you have sport mirrors) then the two bottom ones will just lay out where they will
Diesel_Brad
I am not signed up for anything and the link works just fine
Old 10-20-2017, 07:26 PM
HardScrabble's Avatar
HardScrabble
HardScrabble is offline
Temporarily Deactivated
Old 10-20-2017, 11:21 PM
FordTruckfan89
Only thing is with the type 8, if anything hits the mirror arms, it'll damage the door, they do not fold in at all, mine came with them, one was ripped clean off, other damaged the door, which now needs replacing
Quick Reply: Best Towing Mirrors For A 1995 F350?
