Pull the valves or run it as is?
Ok, so I primed the pump after work today. I changed the plugs, and fired it up. It runs, but I am getting a very low vacuum reading, around 8-10. There's a bit of knock sound on the passenger side. I did a compression check on that side and I get all @ 120. I was going to do the driver's side but my truck is parked next to the neighbor's living room window.
Anyway, if compression is 120ish on the driver's side, should I do a leak down test?
lifted77f250
06-01-2006 02:21 PM
rusty70f100
08-10-2005 09:38 AM
FordOffRoader
04-25-2002 05:57 PM
