my 305 is not looking too good
#46
#47
#49
I called it off and told buddy when I saw there was nothing wrong with the cam. I will mic the lobe out tomorrow and see is there’s room for suspicion with the lobe. I don’t think there is, I honestly think it was either a faulty lifter or something that had to do with the valve train messed it up. But if there is any discrepancy in the lobe then I will ask buddy if I can send it back to comp.
#50
I believe I found out why the lifter was side loaded. I put the engine back together and noticed that the #7 exhaust rocker (all valve train was put back where it came out) was not straight on the valve stem tip. Took it out and the guide plate was bent slightly. Used a spare guide plate, good to go. Engine is going back in tomorrow, I'll change the oil wednesday and post if there is any metal in the oil.
As for other things I did differently, I used RTV around the water ports, this go round I used 93331 gaskets instead of the 95952 gaskets, they didn't fit the intake ports on the head perfectly but they cleared the intake ports on the manifold so they'll work. I had to go through the torque sequence 8 times before they were all permanently at 25lbs.
#52
#54
#55
It's not normal. If the machine shop did a good hone job, the rings should have seated already. Actually the last time. You put the pistons back in the same holes they came out of? Your valvetrain is in good working order? If you're really concerned you can do a compression check.
The only other thing I can think of is building some vacuum. Drive it in first up to some higher RPM's and then let off of the accelerator totally. Letting the engine slow the truck down. It closes off the butterflies in the carb, no air can get in but the engine is still turning RPM building a lot of vacuum. That used to help seal rings.
#56
The gaps weren't lined up were they?
There is a myriad of reasons why it could be smoking out of the breather, number one would be that the pcv isn't operating properly. Do you have a quality pcv to pull the fresh filtered air in through the breather?
#57
This was a big problem on early displacement on demand engines causing warranty issues.
#58
#60
