adding a buzzer
Old Aug 25, 2017 | 11:27 PM
dreamofford's Avatar
dreamofford
adding a buzzer
is it possible to add a buzzer to the oil pressure gauge to warn if the pressure is too low?
Old Aug 26, 2017 | 04:39 PM
JEFFFAFA's Avatar
JEFFFAFA
I never thought about it. Off the top of my head I'd say, "T" in a idiot light oil pressure sender along with your factory gauge sending unit. Like Ford part number D4AZ9278A. It is meant to allow 12V to pass through it when the pressure is low. It grounds the idiot light circuit when the pressure is low. So you would have to use a Bosch style 4 pole relay in between the buzzer and pressure sender. Wire switched 12V to terminals 86 and 30. Terminal 85 goes to the terminal on the D4AZ9278A. Terminal 87 would go to the buzzer. Then ground the buzzer.
Old Aug 28, 2017 | 08:20 AM
mrpotatohead's Avatar
mrpotatohead
You wouldn't need a relay. A two terminal buzzer of any kind will work, just run 12 volts to one terminal and the other to a conventional idiot light type oil sender switch. This is exactly the same circuit as the idiot dash warning light.
Old Aug 28, 2017 | 08:34 AM
ultraranger's Avatar
ultraranger
I think I'd rather have a warning light, to get my attention to look at the actual gauge, rather than having an annoying buzzer going off. But, that's just me.
Old Aug 29, 2017 | 11:54 AM
JEFFFAFA's Avatar
JEFFFAFA
I'm not so sure about that. A buzzer is bound to have more of an electrical draw that a small light bulb. The oil pressure sensor would see that draw if the oil pressure got too low. That sensor would be what grounds the circuit. And it was designed to ground only a light bulb. Which is about the same draw as a relay.
Old Aug 31, 2017 | 08:47 AM
orich's Avatar
orich
2x on
I installed a sensor when oil psi drops to 17lbs the red light comes on.
also have a gauge it lites up ign. not running so your know it's working.
And for the engine temp a gauge plus another sensor 215* that trips a red dash light.
Please no dang buzzer for me!
Orich
Old Sep 1, 2017 | 07:01 PM
SteveJH's Avatar
SteveJH
I'm adding 'ALT' and 'OIL' warning LEDs on my gauge cluster, and a tee was what I'd come up with for the oil sender too but without a relay. I'm going to open the light assembly and use a sharpie on the back side of the LED bezel to mark them. I'll have gauges too, but a bright red light should make for a nice attention getter I think.
I always liked having those idiot lights in my old air-cooled VW and want them in this vehicle as well. Of course, in a VW if the generator wasn't running then the cooling system wasn't running either so it was really critical to know if I'd thrown a belt immediately. It's habit for me to glance down there for them still to this day.
Old Sep 1, 2017 | 07:12 PM
JEFFFAFA's Avatar
JEFFFAFA
I agree. If you're just adding a light then you wouldn't need the relay. That's what the sender was designed for.
Old Sep 12, 2017 | 03:43 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Lightbulb
As an aside, and another option:
A piezo-electric buzzer will get your attention quicker, and will run on tiny currents that would not light a bulb. I ran one side-by-side on a troublesome engine, and found it would start chirping with low or foamy oil, before the incandescent bulb would light.
LEDs are faster than filaments, and gets past the warm-up issue, but the flashes can be too fast to notice with the eye.
I used both an LED, and an inexpensive buzzer from Rad10 Sha<K. Of course, it does blare at you every time you start it up, but that might have some anti-theft benefit. Put it where you can place your thumb on it, to reduce annoyance.
(A piezo-electric buzzer is not like an old electro-mechanical buzzer that uses a lot of juice. You can easily run both at the same time, in parallel, so if one dies, the other still works. No problem for a stock oil pressure switch.)
Silverback01
Dec 3, 2017 07:14 AM
strokeman
1983 - 2012 Ranger & B-Series
Jul 28, 2009 07:10 AM
Domino
Jul 3, 2006 04:23 PM
wipeoutwm
Apr 11, 2006 12:06 PM
ya sure
Feb 23, 2003 02:02 PM
