Engine bogs down when accelerator is pushed
First '77 F150, 400/c6
Problem: Truck would run and drive great but would stall out after about 30 minutes and not start again until things cooled down (usually about 10 minutes of sitting). This pattern would continue.
After some suggestions from you folks here at FTE I changed the distributor pickup coil and the ICM. Thinking that one or both were failing after they warmed up and were preventing startup until they had cooled down.
After getting everything put back together I went to start it up and it did so just fine. I noticed that the high idle was around 1000 which was normal before and it would drop down to about 600-650 after warming up and a push on the accelerator dropped the high idle cam. Only now when I push the accelerator it wants to drop down around 200-300 and sounds like it's about to stall. If I let off the pedal before the engine dies it goes back up to 1000-1100. I can't get it to drop off the high idle and anything other than a quick flick of the pedal nearly stalls it out.
Question, would I need to readjust my idle mixtures, high idle cam, or curb idle after replacing the distributor pickup coil? What about changing those parts would so drastically change the running condition of the engine?
It's not fuel delivery related. In my build up I did new sending units, new rubber hoses, new fuel pump, new fuel filter, carb rebuild and it ran great until it got warm and would stall out. I've never had this issue before.
ICM is Motorcraft
Distributor pickup coil is Standard Motor Products.
While the cap was off I brushed off the carbon on the inside as I've done nearly every time I pop the cap. I've rechecked that my vacuum advance linkage arm is still connected to the pickup coil, and that the vacuum advance hose is connected. While working on it I removed the horseshoe to the ignition coil and cleaned the connections and added dielectric grease before reinstalling.
Maybe you knocked a stuck advance mechanism loose. Maybe you actually did spin the distributor a little (not as likely, but still possible). Or maybe the high-idle cam was actually stuck for a long time and your messing about under the hood knocked it down one notch too.
OR, do you have an electric idle solenoid? Or anti-dieseling solenoid. Or whatever it was called for your year? If so, maybe the wire came undone, or the unit has finally died and your normal idle can't be achieved until it's fixed or the carb is adjusted to compensate.
If you're not familiar with them, the simplest versions from the later sixties and early seventies were there to set the idle with so that when you turned off the key it kicked the idle down a few hundred aditional rpm so the engine would not run-on. In those cases you set the carburetor idle to say, 500 rpm, then adjust the electric solenoid to the usual 600 or 700 or whatever.
Sorry if you knew that already. And because your idle went all the way down to 300, maybe that's not the problem after all.
Likely it's an ignition timing issue, since you were working on the distributor. But simply adjusting the carburetor initially will get you back to where you need to be to stay running (at least until it heats up if you didn't quite fix it yet) so you can check stuff. Then you can check and readjust things properly once you discover what happened.
After that I would definitely put a timing light on it and readjust the timing if necessary. Then of course you'll have to readjust the carburetor again.
Good luck. It seems common that something gets changed even when you're as careful as you can be to not mess with other stuff.
Paul
Who knows what the previous owner did, after buying it I soon discovered that that distributor was 180 degrees out. As in it was set to the exhaust stroke and not the combustion stroke with the #1 cylinder TDC pointing towards the front of the truck and not in the 1 o'clock area as it's supposed to be.
