engine ping
Old Sep 8, 2003 | 10:32 AM
bcwebb's Avatar
bcwebb
engine ping
Need help.
I am at a loss. I have had an engine ping ever since the mass air flow sensor was replaced. Since they couldn't find anything else wrong--major tune-up of plugs, wires, cap, throttle body and engine cleaned of carbon--they have replaced the mass air flow sensor thinking it was defective. No go. It still pings and I am having to burn high test. This is a 93 Explore 2WD V6 with 200,000 miles. Where do I look next?
I've also noticed a hum at 60mph and over. I've rotated tires and put it in neutral and it is still present. I have noticed it is louder when turning right slightly and goes away turning left slightly. Do I have a wheel bearing going bad? THis is a standard transmission.
Old Sep 9, 2003 | 06:33 PM
maa139's Avatar
maa139
engine ping
Have you checked to see if it is throwing any codes? The DPFE (if it has one) or the EGR valve can cause pings. You don't need a scan tool. You can just use a paperclip and watch the CEL flashing to read the codes...The Haynes manual should have the procedures, or there are threads here that explain it very well.
Old Sep 9, 2003 | 10:40 PM
c96drumm's Avatar
c96drumm
engine ping
On the hum, I would agree with you that a wheel bearing is probably it, due to the side to side variance.
Old Sep 9, 2003 | 11:16 PM
mrshorty's Avatar
mrshorty
engine ping
You've missed one common cause of ping on the 4.0 L OHV, a vacuum leak. Make sure all there are no vacuum leaks. One common vacuum leak is through the lower intake manifold. For some reason, the lower intake manifold bolts come loose over time. Try tightening them. Usually that will fix it. If not, you may need a new lower intake manifold gasket.
Old Sep 10, 2003 | 04:54 AM
Opera House Works's Avatar
Opera House Works
engine ping
When all else fails, change the fuel pressure regulator.
Old Sep 10, 2003 | 05:44 PM
Juangmoexplorer99's Avatar
Juangmoexplorer99
engine ping
What is CEL??
Old Sep 10, 2003 | 06:27 PM
mrshorty's Avatar
mrshorty
engine ping
CEL=Check Engine Light. Repair manual like to call it the "malfunction indicator lamp" or MIL.
Old Sep 11, 2003 | 02:30 PM
bcwebb's Avatar
bcwebb
engine ping
Thanks mrshorty, I'll check for the vacuum leak and manifold. It is not listing any codes.
