Broke my truck, what flexplate do I need?
Old 07-22-2017, 05:57 PM
96halfton's Avatar
96halfton
96halfton is offline
So I was driving home from lunch yesterday when the truck suddenly started shaking and then reved like it had slipped out of gear. Well I had to stop on the road and tried restarting the truck and nothing, the starter just spins. From what I can tell I broke the flexplate. Now I am a little confused as to what flexplate I need. I need a 50oz for my 96 correct? Do I need 157 or 164 teeth as both are coming up for a 302? I am also going to change my rear main seal, is it a 1 or 2 piece seal? I'm also considering ordering a shift kit to install while the trans is out anyway. Anybody used one of the transgo or B&M kits?
Old 07-22-2017, 06:36 PM
wtroger's Avatar
wtroger
wtroger is offline
It would help if we knew the year of the truck.. I will assume it a 96. If that is true and engine is the original then main seal will be one piece. Looks like 164 tooth.
Old 07-22-2017, 11:31 PM
ChRoNo16's Avatar
ChRoNo16
ChRoNo16 is offline
Always good to take out the flexplate and count the teeth.
Old 07-23-2017, 07:41 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
Remember to retorgue those 1" 10mm x 1.0 flex plate (fine pitch) bolts to the manufacturer specs -- funny things happen if you don't.
NCFarmLife
08-03-2017 02:10 AM
rageinside
02-12-2016 08:53 AM
Tony.
07-07-2015 07:59 PM
mototrig
06-26-2014 11:33 PM
MatthewC
1978 - 1996 Big Bronco
08-29-2004 02:13 PM
Quick Reply: Broke my truck, what flexplate do I need?
