High rpm high speed ping
2011 Ford E350 v10. 200k. I had a ping that was greatly reduced after a plug change but was still there at high rpm above 3500 and higher speeds 70+ at wot. Did the Seafoam treatment and it reduced it to high rpm high speed with 7k towing I can hear it. Then after a couple of weeks it came back. I installed mikes 5 star tune and it only does it at high rpm high speed with towing again . Checked cats, replaced purge valve solenoid, fuel pressure, maf. No codes ever. For about a week the truck was hard starting and ran rough. Then went away. Mechanic said fuel injector leaking. Then it smoked on startup for a few days then stopped. Also said maybe leaky fuel injector.
Could a fuel injector be causing this. The ping comes from the passenger side of motor. Has anyone done a fuel injector cleaning or decarbonizing treatment? Where would a good place go and does it work. Instead of searching for a specific injector.
I had the plugs were just changed and all were coated with white crusties. They even wentback and checked after wards because it was still doing it and it looked fine. But I will look at them again. Like I said. It did it literally two times and that was it. It did the long cranking for a week or so, it was almost like the fuel system bled off.
npccpartsman
06-11-2017 03:07 PM
Dogs-in-the-back
01-03-2007 05:24 AM
