Cab Lights or No Cab Lights?
I am ordering a 2017 F350 SRW CC SB, Lariat ultimate FX4 because I know exactly what options and configuration I want, except whether or not I want to opt for the clearance lights. My main concern is fitting the truck in my garage. Do the clearance lights add to overall height or inhibit the ability to get your truck in the garage? I have about 81.5" of clearance, with a slight incline to the garage door. I like cab lights, but don't need to have them, so it's making a small decision quite difficult.
Received 6,693 Likes
on
My F350 long box, lariat on 18" wheels with stock tires is just over 81" tall. If you do a front level or larger tires, your cab at the back is going to squeek through your door just barely. With a level, the cab lights will be just as high as the back.
I recommend you test drive and do a test fit very carefully with a cab light model with same wheel and suspension package you plan to order. That's what I did to test my current long box, just to be sure on length. My old 2005 short box was 6'8" with larger tires, and fit in the park are at work. My new long box no beuno at work, had to move outside.
Because your drive is sloped down at the entry, you just might make it. I had the opposite issue with one entry into the parade, *** high, meant the back of the cab on the old truck was very close to the entry at the door. Once in and level no problem, but the one entry way was very concerning.
on
You might want to look real close at the specs with your door opening height of close to 81.5". The truck you are wanting is listed at 81.3" tall without options in the Ford spec. sheet. Options can be many things but in my case it was 20 inch wheels which add 0.20" in height. On my F250 listed in the spec. sheet as 81.5" it ended up being 81.7" tall.
I ordered the same truck a few weeks ago (I just got my VIN yesterday). I had the exact same dilemma regarding cab-lights and clearing the garage (same opening height for me, also with a slight uphill slope to the garage threshold).
I ended up skipping on the lights to help my chances. However, I now realize I shot myself in the foot because I ordered the 20" wheels without doing the math and recognizing that they would lift the truck.
I've attempted to do the garage geometry calculations and there is a very slight chance the truck will still fit owing to the wheelbase and that uphill slope to the garage threshold. However, standing next to one of these trucks on the lot, I'd say there is absolutely no chance. It will be a good while (6-9 more weeks) before I know the outcome. (I guess that gives me time to research hail protection.)
No way mine's going in the garage (wife parks in there and there's no way I'm parking next to her!) so I wanted the cab lights since they can't be added easily. I didn't order, and I'll tell you this...once you add cab lights in the search criteria, it really cuts down on the trucks available. I'm guessing there are more out there without than with. No leaking issues with mine, though and we've had 11+ inches of rain this week.
I have my F350 Lariat on order and took months to agonize over every option. I decided not to have clearance lights due to the chance of leaks. I decided I did not need them and the risk of leaks was too high. It was never about the money. Good luck on your truck.
Feel the same way about 2 huge a__ holes for moon / sun roof. I do like em and think they're neat..... But not on my truck. It will leak..... It's just a matter of wheen.
Just MO.
