'88 302 high HC
Old 09-02-2003, 02:08 PM
sumdumgai's Avatar
sumdumgai
sumdumgai is offline
'88 302 high HC
Experienced high hydrocarbons on my '88 F150 (155K mi.) and failed emissions. Changed plugs (old ones looked like they were burning clean), dist cap, rotor, PCV, air filter, oil and oil filter. HC's dropped but not enough, and failed again. On third try, I shot some synthetic 'gum-out' carbon deposit removal stuff made by Valvoline down the throttle body throats and the HC's dropped to max allowed so it finally passed.
Question is: I'd like to get HC's even lower, so what other steps can/should I take?
Thanks for your help.
Old 09-02-2003, 05:46 PM
mantta's Avatar
mantta
mantta is offline
'88 302 high HC
You need to bring your combustion performance up. First of all I would do a compression check, check out your engine vacuum and ignition timing. Any of these can bring your HC count up because of incomplete combustion in one or more cylinders.
timbuctooCal
12-08-2013 07:29 AM
casmus
01-07-2013 12:27 AM
Homeslice
10-05-2012 05:48 AM
Machman
25
05-13-2012 12:04 PM
bones68
Bronco II
08-14-2007 03:57 PM
Quick Reply: '88 302 high HC
