Cylinder PSI on 1971 302 - all low
I'll check out the other website and hopefully will be able to find out what engine this is.
My son checked out the other website and he says it's a 351. There are 6 bolts on the valve covers and the area around the distributor sits up about 1-2 inches higher and there's a small lip behind the distributor.
Does that sound right?
Then, for ordering parts for the engine does it really matter what year engine we have for parts? Or, will all or most 351 parts work?
The Dura Spark is a good ignition system. Get a 15/16" socket to use it to rotate the crank shaft to feel the timing chain slack. Mark the harmonic balancer and check with a ruler , if there is more than 1/2"-3/4" free movement you need to address the timing chain replacement. It looks like the vacuum advance is turned to the right as far as it can go which indicates a loose chain.
The Motorcraft/ Autolite carberator is the easiest one to rebuild and will help to smooth out the engine. Try to replace all the vacuum hoses also.
Tag on the distibutor
48 D9SE 12127 AA 8J-08
Printed on the dipstick above the full line
DOAE=6750-C Ford M
I didn't see anything on the carburetor.
I don't have a microfische crossover slide old enough to cross D0AE6750C. Back then usually the engineering numbers and part numbers went hand in hand. So I am assuming that dipstick was part number D0AZ6750C. Which was replaced by D5OZ6750A. Then discontinued.
D0AZ6750C....69/72 F100 with a 302. 70/72 cars with a 351W.
D5OZ6750A....73/75 F100 with a 302. 73/75 cars with a 351W.
So it is my guess the PO got a 1979 351W out of a T-Bird or Crown Vic in a wrecking yard. Installed it. Then couldn't find the dipstick so they stuck the dipstick from the truck's original 302 in it. 302 and 351W oil pans have different mount pattern to the block. So your engine should still have it's T-Bird or C/V oil pan on it. The T-Bird oil pan was the usual Car front sump pan. The C/V one was different. Maybe even dual sump pan. Take a look at your oil pan to see which one it is.
351Ws from 1969-1975 had (16) intake bolts, L-shaped water passages at the ends of the heads (the intake would have to be off the engine to see the water passages), and had 18mm sparkplugs requiring a 13/16" socket to remove the sparkplugs.
'76 and later 351Ws had (12) intake bolts (just like the 289s/302s), rectangular water passages at the ends of the heads and 14mm sparkplugs requiring a 5/8"socket to remove them. The '76-later carbureted 351W heads (302s of this era as well) have smaller intake and exhaust valves than previous years and bigger combustion chambers --read; super sucky, low compression, smog heads.
86stepsideF150
41
03-03-2017 07:44 AM
HardFordCore
06-01-2009 12:00 AM
muscletruck7379
12-20-2006 12:10 AM
