1981 straight six manual 4x4 project
  #46
Old 05-03-2017, 04:51 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
See if this works for you: Brakes - ???Gary's Garagemahal. And, if it doesn't or if something is missing PLEASE let me know.
  #47
Old 05-03-2017, 05:02 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,759 Likes on 1,425 Posts
Originally Posted by Ford F834
Thanks for checking into the brake pad question. I will wait to order. I don't trust the parts house computers to steer me right.
Never mind on the D50 upgrade. I guess it requires some modification and is just done because it's bigger and stronger. I'm not running big tires, I'm not lifting it, and I'm not into hardcore rock crawling or anything so stock is fine I was thinking it was a direct part swap but I just read that it's not.
Yes, you need to clean those dovetail slides and put never sieze or some sort of high them grease on them. If these slides stick, then one pad will wear more than the other, so when you pull them apart you can check them and see if they were sticking. Also the calipers sticking is a common problem, rust builds up behind the pistons and when they are pried back for new pads they piston is shoved over top the rust and it starts sticking.
Your slip yoke does not need a upgrade, the main problem with them is grease worms. They get in there and eat all the grease out and then it wears out. If you are going to replace that get ready, it may be a little expensive, I haven't bought one lately, but when the yoke wears the axle wears also. So you need the yoke and the axle, and years ago I bought the axle for $150.00.
  #48
Old 05-03-2017, 07:11 PM
Ford F834's Avatar
Ford F834
Ford F834 is offline
Thanks Gary, everything seems to be working. The only problem is the highest GVWR mentioned anywhere on the list is 5,150. The '82 4x4 says 5,700 on the certification label, and the '81 4x2 says 6,100. So technically they don't fit the list. The list shows different pads for 2wd and 4wd, so I guess I'll just order pads for a 4x4 and see how they fit. The pads looked the same on both trucks. Thanks again for the web page. Your site is such an awesome resource!
  #49
Old 05-03-2017, 07:24 PM
Ford F834's Avatar
Ford F834
Thanks. The play is not that bad, I will probably just leave it for now. It is tempting to let this thing snowball and do a full 100% overhaul on everything, but I have to behave. Yes, it is worn but far from total failure. I will fully overhaul this drive train piece at a time once my diesel build is finished. And I think you're right, the '82 donor was heavily infested with grease worms
  #50
Old 05-03-2017, 09:09 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I'll check it out. Maybe I missed something.
  #51
Old 05-04-2017, 10:48 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I think the way I read the catalog is different than the way you are reading it. As shown below, since the 80/83 4x2 entry has no GVW given, I think it is for all 1980 - 83 4x2 F150's and F250's.
Does that make sense?
  #52
Old 05-05-2017, 12:13 AM
Ford F834's Avatar
Ford F834
Thanks Gary, I don't know what I was thinking... I was looking at the list completely wrong. It is still showing different calipers for 2wd and 4x4, and no entry for 4x4 lining and pads... but I am probably over thinking this whole thing. This morning after my night shift I managed to finish getting the TIB under the donor. I left the calipers tied out of the way during the swap, and I now know that the 4x4 calipers fit the 2wd knuckles, and the used 2wd pads fit with the 4x4 calipers. I think I will just buy brake parts for a "1981 F150 4x4" and see how they fit.
Glad to at least have the donor back on the ground:
  #53
Old 05-05-2017, 06:17 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Good job... time for some rest!
  #54
Old 05-05-2017, 06:38 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Yes, good job.
Do you think it would be helpful to put notes similar to that shown above on the catalog listings on the web site? And, I'm thinking I should at least highlight the generic part numbers, like 2001 and 2120, as it is hard for me to pick out the breaks - or is that brakes. .
  #55
Old 05-05-2017, 08:26 AM
Ford F834's Avatar
Ford F834
I believe it would be helpful. It would be interesting to compare the Ford list to a list of aftermarket service parts. I bet there are fewer parts that fit more applications.
As much as I hate to leave the 1981 literally up in the air... on blocks with no axle under it... this weekend will be for family time. I plan to order some parts and research how deep I want to dig into this front end at this time.
Couple of quick questions regarding tools...
Does anyone know off hand exactly what I need to take apart the front 4x4 hubs? Size of spindle nuts? I don't own any of these special tools and I believe I will need them to get the rotors off for turning and to replace the damaged lug studs.
Does anyone have any recommendations on tools to remove and install the pivot bushings? Should I make my own threaded pullers and presses or are there readily available tools that work well for this. Mine are not that bad but it seems senseless to pass up the opportunity to change them since the axles are out.
Thanks for all the help and good info.
  #56
Old 05-05-2017, 08:37 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
The spindle takes the tool shown below. For pressing the bushings I've used hardened all-thread and sockets. But be careful if you have a sheetmetal axle as you can bend it if you don't press at the right spot. Don't press a bushing into one side and put the socket on the other side of the axle or you can pancake the whole axle.
I haven't pulled the rotors off the hubs yet, so can't answer that one.
  #57
Old 05-05-2017, 12:04 PM
Ford F834's Avatar
Ford F834
Thanks Gary, I guess I would not get so lucky as to have one tool fit my D44 and F350 D60 hubs ...
  #58
Old 05-05-2017, 12:25 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Why would , the company that puts a number that isn't the part number on a part, use the same tool on different hubs? That just makes too much sense.
  #59
Old 05-05-2017, 12:31 PM
1986F150six
Time for another cup of coffee, Gary!
  #60
Old 05-05-2017, 12:51 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Well, I've had 3 cups so far today, and I'm working on water now. But, I'm sure another one is in the offing for later. However, in some ways the coffee has helped, as I got quite a bit done on the web site this morning, and then tried to pull the neighbor's tree out of the ground: https://www.ford-trucks.com/forums/1...l#post17168432.
Jonathan - That socket wasn't expensive, but I've heard of guys grinding a regular socket down to use instead. If you need the dimensions just let me know.
Quick Reply: 1981 straight six manual 4x4 project
