90 460efi no start
Old 09-01-2003, 09:43 PM
ryno_co's Avatar
ryno_co
ryno_co is offline
90 460efi no start
Hi Folks, Hope someone here has some ideas to help me.
Truck died coming home from work and refused to start.
I pulled some codes and got an334 and 128 ( as i recall) The 334 is EGR closed voltage higher than expected and 128 is MAP vacuum circuit failure. I checked the vacuum line to the MAp and it had a small crack so I replaced it, but to no avail. I have 40psi fuel pressure on the rail and I have spark. Anything else I should be checking. Thanks Ryan
Old 09-17-2003, 01:06 PM
c_rossman's Avatar
c_rossman
c_rossman is offline
90 460efi no start
Wow interesting, I would maybe try disconnecting the battery for a few hours to clear the computer. During start mode, the computer ignores the Map and EGR sensors so you should atleast get a fire or two.
Old 09-17-2003, 02:32 PM
HardScrabble's Avatar
HardScrabble
HardScrabble is offline
Temporarily Deactivated
90 460efi no start
Can you test to see if the injectors are getting pulsed? Listen with a stethoscope or tube or check with noid light. Check power to injectors. Could prime the intake and see if you get a hit.
If you pull a plug you can do a rough timing check, see if it sparks on compression stroke.
Old 09-17-2003, 10:30 PM
ryno_co's Avatar
ryno_co
ryno_co is offline
90 460efi no start
Thanks for the replies guys. I took the the truck to a mechanic and he checked a few other things out. Said it has signal to the injectors and the timing is correct. It does turn over hard. He had a rebuilt starter and fresh battery so he tried that out and still turned over hard. He suspects internal engine damage of some sort. ???????? I have tried starting fluid and it usually will fire and run for maybe a second or so. I towed it back home and figured I'll mess with it this winter when I have more time. Any other suggestions/ideas/advice would be great.
Old 09-17-2003, 10:57 PM
c_rossman's Avatar
c_rossman
90 460efi no start
Yeah, It could be the timing chain, slipped a few teeth. Or broke?Take the distributor cap off and see if it rotates when turning the motor over.
