1948 f1 transmission/clutch "stuck"
I believe Ross is saying the clutch disk is flipped, backwards. At first glance, I thought it was correct but now I believe I may have blown my answer. Yes, better pictures are needed.
So far as the OP second picture and question, I don't know what your question is. Normally the yoke fits into a bushing in the tailpiece and the splined shaft fits several inches into the yoke.
Thanks Kevin! That's exactly the pic we need from F-1.
As far as the yoke, is there a seal iin place on the rear bearing retainer/mount? The yoke needs to go thru the seal. I don't see anything wrong, the yoke just isn't pushed all the way on. If that's as far as it goes, then something is wrong.
'48 f1 truck clutch stuck
Ok..fingers don't move at all?? here's a pic of pressure plate showing clutch plate..should I remove pressure plate to see if those pressure plate fingers move at all?? original pressure plate..new clutch plate..drove it w/no issues for 2 years w old pressure clutch plate..and now new clutch plate w/ correct springs etc..?? I think??
I'm gonna yank that pressure plate to see if I can get those fingers to move..gone this far..what say you??
u?
u?
u?
u?
