2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
What's the wheel bolt pattern 17' F350 DRW?
Old 02-15-2017, 05:11 PM
DuallyNewt's Avatar
DuallyNewt
DuallyNewt is offline
Getting new wheels but can't find bolt pattern. Does anyone know. BTW it's a Dually.... Thanks
Old 02-15-2017, 05:14 PM
bronc71's Avatar
bronc71
bronc71 is offline
8x200 been the same since 2005
Old 02-15-2017, 05:17 PM
Sleepyguy's Avatar
Sleepyguy
Sleepyguy is offline
This has loads of information on it if you are looking.
2017 Ford Super Duty | View All Ford Super Duty Specifications | Ford.ca
Old 02-15-2017, 05:19 PM
Sleepyguy's Avatar
Sleepyguy
ever mind whoops
Old 02-15-2017, 05:20 PM
bronc71's Avatar
bronc71
bronc71 is offline
Originally Posted by Sleepyguy
Um 8x170 I believe.
Not for a dually
Old 02-15-2017, 05:32 PM
bluewaveaudio's Avatar
bluewaveaudio
bluewaveaudio is offline
I ordered the cali off-road chrome 20'' wheels for my truck but are on back order for 3-4 weeks.... going with the 35x11.50x20 nitto ridge grappler
Old 02-15-2017, 05:36 PM
DuallyNewt's Avatar
DuallyNewt
8X200 Thought so.. Thanks so much
Old 02-15-2017, 11:03 PM
mbovinet's Avatar
mbovinet
mbovinet is offline
Just did a set of those in black on mine. Nitto Ridge Grapplers but 295/65/20 instead
Old 02-28-2017, 07:38 AM
lchlucky's Avatar
lchlucky
lchlucky is offline
Do either of you have pictures of the Cali Off-Road's on the truck? Do the rears poke out beyond the fender and do the fronts rub at all? I assume you both have a level kit installed in the front.
Old 02-28-2017, 07:43 AM
mbovinet's Avatar
mbovinet
mbovinet is offline
No level kit. No rubbing. Yes the rears stick out
Old 02-28-2017, 08:01 AM
lchlucky's Avatar
lchlucky
lchlucky is offline
Thanks, it looks like the spacing in the rear is about half of stock maybe a bit more. What gears do you have on your truck and do you happen to have a full side shot including fronts?
Old 02-28-2017, 08:03 AM
mbovinet's Avatar
mbovinet
mbovinet is offline
3.55
Old 02-28-2017, 08:09 AM
lchlucky's Avatar
lchlucky
lchlucky is offline
Thanks that looks good. Wondering what RPM a 4.30 would run those at 75MPH. Also noticed that for some reason the load rating on the inner rear wheel is only 2500 vs 3200 for the outers. I would of thought they could have put more material on the inner to increase its capacity.
Old 02-28-2017, 10:14 AM
Ruby350platinum's Avatar
Ruby350platinum
Ruby350platinum is offline
Wow now that's a nice combo.
Old 02-28-2017, 11:34 AM
bronc71's Avatar
bronc71
bronc71 is offline
4.30 gear would only be for a gas truck not a diesel in a 350drw
Or a 450
I think your referring to 4.10 gearing
Quick Reply: What's the wheel bolt pattern 17' F350 DRW?
