KOEO code assistance por favor!
A= Canister Purge solenoid (EVAP) (CANP).
B=Vacuum check valve (VCKV).
C= Should go to the EGR control Solenoid (EVR).
D= Secondary Air Injection Diverter Solenoid (AIRD)
E= Secondary Air Injection Bypass Solenoid (AIRB)
F=Fuel Pressure Regulator (FPR).
G= Hose to EVAP.
H= Fuel tank vent hose to Canister.
G= Hose to EVAP.
Couple of follow on questions if you don't mind. First, since my EGR doesn't hold vacuum after I did that test - does that mean I need to replace it or can it be "cleaned"?
Additionally, your diagram shows three solenoids next to each other, but I'm only seeing two in my truck (D&E). Does that mean my truck is missing one or could it be that my truck was not outfitted from the factory? I'm assuming that the third one should be mounted on that exposed bolt to the right if I'm supposed to have one and that D = EVR solenoid, E = AIR-B, and the missing one should be the AIR-D?
Do I need to loop the AIR-B & AIR-D in if I don't put the Air Injection back in?
Thank you kindly!
S/F,
-Matt
Yes if the EGR valve does not hold a vacuum it has a hole in its diaphragm and the EGR Valve needs to be replaced.
What I am not seeing is the EGR vacuum regulator solenoid (EVR), it looks like it is missing.
It looks like the vacuum lines for it is at "C" in your photos above.
The diagram is for a 1995 4.9L but without your calibration code off the drivers post it may not be the right diagram.
OR the left solenoid may be the EGR solenoid and D maybe missing as I can not tell for sure.
An EGR solenoid:
An EGR solenoid:
An EGR solenoid:
An EGR solenoid:
I'll order up a new EGR valve/gasket and hopefully that and the new vac lines will fix the atrocious fuel mileage I'm getting. I can't imagine I'm getting better than 8-9 mpg right now.
Oh, and if the AIR solenoids are missing should I just not plumb them into the vac system or are they needed for no codes as well?
Thanks again for everyone's assistance, y'all have really helped me get this truck back on the road.
KOEO Codes- Videos, please ID the codes...
Hello all; my diverter valves and smog pump have been disconnected and capped off; next is the pump delete and an 87.5" belt, followed by the cat. So, after replacing all the bulbs in the cluster and replacing little parts, I snapped a video of the codes; I'm much more fluent with OBDII; can someone please translate to me what I have? Videos located at:
https://1drv.ms/f/s!Ahhgci7C2SB4gadmLeKkyTcegUrPYQ
TY!!!
TY!!!
TY!!!
TY!!!
Anywho, I took half a day today and ran down to a JY south of Dallas that had a '96 E150 Econoline van with the 4.9 with A/C...needless to say, I picked up some goodies.
Extra Solenoids and the Air-D that I'm missing - figured out where that hanging plug was supposed to go!
Smog Pump and lines - though it appears that I'm missing some other stuff, it's a start I supposed.
And a new alt/smog bracket to replace my broken one:
And, I know it doesn't make with the topic of this thread, but secretly it's my favorite find today; Saginaw steering pump & bracket:
So tonight I was able to:
A) Install Air-D solenoid
B) Replace the broken Alt/Smog Bracket
C) Install that wonderful Saginaw pump - man o man, what a difference. Completely plug and play, minus a slight tweaking of the van high pressure line. It steers so, so, sooooo much better.
Anyway, after I cleaned up I also realized that my box with the new vacuum lines came in today too. So tomorrow I'll replumb the vacuum lines and hopefully next week my new EGR and O2 sensor will come in. Fingers crossed that it will clear my CEL codes...actually, do I need to clear the codes? Or will it clear itself? More research...
This extension cord for the reader makes getting the codes from the truck so much easier. Otherwise you ma7 need another person to help you out ( )
#28
#29
Afternoon gentlemen!
Ok so I've been busy this weekend!
I about murdered myself getting the dang EGR valve out...in fact, I wasn't able to until I removed the passenger side inner fender and took the pipe off from the exhaust manifold. Someone previously cross-threaded the old EGR valve on. I actually just had to order a new one as if I try to re use it I'll just cross thread the new one. Total pain in the ****.
Anyway, I also tackled the vacuum system. I do believe I have the vacuum hoses re-routed properly for an "Air Delete style system", but would appreciate it if anyone more in the know would tell me if I have it right:
Thanks!
S/F,
-Matt
Thanks!
S/F,
-Matt
#30
On the EVAP system - does VAC CAN = vacuum canister or charcoal canister? Two different things... You need the charcoal canister where you have VAC CAN. At the throttle body you 2 lines - just checking but you didn't plumb them to the large coolant fittings right?
On the EVR circuit you should have the Vacuum canister in the supply side between the manifold tree and the EVR. Vacuum signal varies as the engine RPM's change and the vacuum canister helps to provide constant vacuum to the solenoid.
