Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
TSB?
Old Jan 20, 2017 | 11:31 PM
sbraatz's Avatar
sbraatz
TSB?
I've got a '16 escape with 17K on the meter and it squeaks in wet weather. Does anyone know if a TSB has been issued regarding the right rear suspension squeaks? It just so &%#&* annoying dealing with the dealership.. Any ideas? Will replacing the sway bar bushings and end link bushings solve the problem?
Old Jan 21, 2017 | 03:25 AM
simonsi's Avatar
simonsi
Swap the rear shock absorbers from side to side and see if the squeak moves.
Not sure any manufacturer would issue s aTSB for such squeaks, they will be a bush failing or tight shock absorber of some kind, a normal maintenance issue they would see it as.
Old Feb 3, 2017 | 01:08 PM
dans 51 f2's Avatar
dans 51 f2
there is a recall or tsb for the rear shocks. both rear were replaced due to noise under warranty.
Old Feb 4, 2017 | 07:00 AM
wptski's Avatar
wptski
They don't issue a recall for something like that and TSBs are followed "only" if you bring your vehicle in to complain about a problem that it addresses. Getting a TSB done just because there is one can be difficult.
bumparker
Feb 18, 2012 03:01 PM
2000navi
Nov 30, 2009 12:37 AM
528bmw
Feb 3, 2004 10:16 PM
southprk
Dec 26, 2003 08:08 AM
