Brians project Road Rash
#302
#304
#305
#308
Brian, one tip when you weld the corners on. Have the doors on the cab, to make sure the body lines match up! I made the mistake of NOT doing this, and one side is a little out of alignment with the doors, so, I'll have to do a little cutting and moving things around!
Edit: Just saw that this corner doesn't go all the way to the door, nevermind!
#309
#311
Thanks Pat. I figured that I would only remove enough to be able to do the inner panel. I took the opportunity to OSPHO the inside of the cab corner while it was all opened up. Access is much better with it open.
#314
#315
I spent some time this weekend trying to get the cab corners buttoned up. Driver side is real close. Still some grinding to do. The passenger side is not as far along but it too is close. I am trying to justify the purchase of a spot welder. I am almost convinced. Who am I kidding, as soon as I can get to the store I'm getting one. An inexpensive one through Harbor Freight.
On to some photos. Driver sided inner panel seam sealed and prepped for spot welding.
Passenger side seam sealed.
Both outer cab corners were prepped after a long period of adjustments. Trying to get them to fit as nice as possible.
This will need a little more clean up before I'm ready.
My gran-kids showed up on Easter so my weld clean up got put on hold. Happy Easter everyone.
