It finally happened!!!!
Received 3,755 Likes
on
yeah but I have worked on the same years with trucks and see frame cracks, steering gear boxes bust out of the frame, cab mounts crack out of the cab, radiator core supports corrode away, sheet metal start degrading, wiring starts shorting as the insulation degrades, brake lines and hoses rotting,
on
if you figure 50 mph as an average that is 1.5 million miles. steel or aluminum it is a lot of a fatigue
on
His jeep has been parked in the woods for the past year and a half because he started replacing the floor and then started over complicating everything.
Im sure the OP will take the measures to give the truck a good once over before he drops a motor into it.
Next time you intend to scrap a truck due to metal fatigue, call me first.
kr98664
02-15-2022 01:24 PM
78Explorer
General Automotive Discussion
11-14-2004 10:13 AM
