passenger side exhaust leak
Old 01-05-2017, 03:42 PM
fordf2501's Avatar
fordf2501
fordf2501 is offline
how hard is it to replace the passenger side exhaust studs and gasket? it is on a 2001 f250 5.4 4wd i know for a fact that two studs are broken on the back part of the manifold and it is leaking bad.
i found new stainless steel studs for 15 on amazon is that a good idea?
Old 01-07-2017, 07:24 AM
96f150's Avatar
96f150
96f150 is offline
It can be done...just take your time. I have done the pass side on my 01 twice in 5 yrs. remove the wheel well liner to gain aceess easier. I had 2 that wouldnt come out also. I welded a nut onto the end of the broken stud and it backed out easily. I think the heat from the welding also helped free it up
Old 01-08-2017, 01:05 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,203 Likes on 828 Posts
Also have your exhaust manifold resurfaced or get a new one, if not you will find yourself doing it all over again. Make sure to use copper antiseze when instatilling the new studs/bolts.
buttz
09-01-2015 06:59 AM
BuckHammer
22
03-15-2011 07:21 PM
raceman3
1997-2006 Expedition & Navigator
07-31-2008 03:10 PM
kfnpemai
1997 - 2003 F150
12-30-2005 11:26 PM
brianas
1999 to 2016 Super Duty
02-19-2004 09:57 AM
Quick Reply: passenger side exhaust leak
