460 2g to 3G alternator ?
Old 01-24-2017, 02:22 PM
mrollings53's Avatar
mrollings53
mrollings53 is offline
Originally Posted by ArdWrknTrk
And the 95A body is only 135mm in diameter.
The larger 148mm body of a 130A alternator requires clearancing (or just get the wider spread 8.25" mounting)
Earlier 3G's had an 8mm hole that can be tapped to 3/8-16 for the tension bolt. Later ones with the 10mm hole need to be helicoiled, or use a bolt & nut (but I don't have three hands to hold the pry bar and both wrenches)
Or, I just buy a 7" 3g 130 amp alt, and not have to deal with finding different brackets.
Jam a wrench on the bolt head then torque the nut down. Use a lock washer to keep the bolt from spinning when turning the ratchet.
  #32
Old 04-03-2017, 11:03 AM
zer01's Avatar
zer01
zer01 is offline
A friend had a 2002 Taurus with 3.0, anyone know if this will work? I have a 1992 f350 7.5, 7" mounting ears. Got the harness plug with it.
  #33
Old 04-03-2017, 11:09 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
EDIT**** 2002 will not be a 3G and likely be controlled by the computer.
I'm not sure on this.
Sorry, . I was thinking 1992....
If the larger (148mm) body of the 130A unit will fit the only concern might be clocking, and that is easy to change.
  #34
Old 04-03-2017, 12:12 PM
zer01's Avatar
zer01
zer01 is offline
Thanks, wasn't sure
  #35
Old 04-03-2017, 05:32 PM
Pappawheely's Avatar
Pappawheely
Pappawheely is offline
I get a same year 130 amp E350 alternator and switch the case to get the smaller bolt circle.
  #36
Old 04-03-2017, 06:39 PM
seagiant's Avatar
seagiant
seagiant is offline
Hi,
Nice write up!
I bought a new REMY G3 for my 89 F-150 4.9L.
I had to reclock to get the B+ Terminal in the right place and grind a little on the hanger!
No big deal and is the best upgrade I have done!
  #37
Old 04-03-2017, 06:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm not sure what you're saying here....
2G's come in two case sizes 95A 4 hole 135mm and 130A 2 hole 148mm diameter.
The case halves cannot interchange
Both current alternators come in a host of different mounting styles.
We have the 7" & 8.25" pivot mounts
8mm threaded or 10mm un-threaded.
There are also side mounts, and an odd 'V' style mount for mod motors.
​​​​​​​Just choose the right donor and the most you have to do is clock it if the wires aren't pointing correctly for you.
  #38
Old 04-03-2017, 09:56 PM
_Trekker's Avatar
_Trekker
_Trekker is offline
Originally Posted by justcruzin125
I bought a rebuilt one at autozone from a 95 mustang 5.0
This^ the Taurus one wouldn't fit my 88 460, the mustang 5.0 fit perfect but it isn't threaded so I had to use a bolt and nut rather than the bolt that was in it before
  #39
Old 10-21-2020, 08:15 PM
Mohwak's Avatar
Mohwak
Mohwak is offline
Just wanted to put this out there because there seems to be some confusion about the 460 motor. If you have the poly-vee belt system on your 460 then you should get the 7 inch pivot mount. The older v-belts can use 8.25 because the adjusting bracket is different.
The following users liked this post:
RJ sheedy
13
10-26-2016 03:56 PM
BearFootCustom
19
03-25-2016 06:51 PM
74FordNut
08-28-2015 11:56 PM
MRFIESTAS
18
01-18-2015 10:25 AM
kogler
02-02-2005 12:03 AM
Quick Reply: 460 2g to 3G alternator ?
