1966 Ranchero
Should be a toploader Ford trans. V8, right? What's wrong with it? Just the shifter? Is it a stock Ford shifter? Have you checked the shift rods etc? The second link has shifters, and you can probably get them through Summit, Jegs etc. Those would be aftermarket, preferably Hurst, shifters.
Several sources for these.
https://www.5speeds.com/toploader.html#kits
4 Speed Toploader Parts
Depending on how far gone your 4 speed is and your other goals, there are other options here:
https://moderndriveline.com/catalog/Ford_Solutions.htm
