2017-2019 Super Duty FORScan Spreadsheet
Old Dec 26, 2016 | 09:00 PM
  #61
EpicCowlick's Avatar
EpicCowlick
New column added to the spreadsheet to show each feature status.
Thanks AllGoNShow for the screen icons. It's added to the spreadsheet as a single confirmation until others confirm also.
Show Temps on Gauges feature status set to "Does Not Work"
By the way, if anyone sees an error on the spreadsheet please report it. I'll fix it right away.
Old Dec 26, 2016 | 11:36 PM
  #62
AllGoNShow's Avatar
AllGoNShow
Originally Posted by hollapm
The quickest way to the messaging seats is to push the center button on the seat (drivers use your left hand, put is straight down to where the directional wheel is and push the center button. Turns on the seat massagers. It is the easiest/quickest way ;-)
Well I'll be damned, nice tip!
Old Dec 27, 2016 | 06:46 AM
  #63
gpf2ez's Avatar
gpf2ez
Was the spreadsheet in the first post abandoned for the F150 spreadsheet?
Old Dec 27, 2016 | 07:51 AM
  #64
EpicCowlick
The spreadsheet in the first post is meant to include confirmed changes for the Super Duty only. Many of the F150 changes don't apply to the Super Duty. Right now there's a whopping 4 items that have been confirmed but over time that will increase.
Old Dec 27, 2016 | 10:36 AM
  #65
BigJoeT's Avatar
BigJoeT
Has anyone tried the mirror auto fold that the f150 guys have been doing?
Old Dec 27, 2016 | 12:30 PM
  #66
AllGoNShow's Avatar
AllGoNShow
Hey Epic,
Interested in making a folder for people to submit their as built data for comparison between the models? Not sure how helpful it is, I know the other Superduty thread was doing it for commanded regen screens.
EDIT** Epic, I am also on Sync v2.0 that I tested the Heated/Cooled seats features. v1.0 designation is carried over from the F150 spreadsheet but my '17 is indeed v2. I did notice one "Settings" screen icon must have disappeared as my massaging seats moved from being alone on the 3rd page to the end of the 2nd page, will try and flop back and forth later today and see what icon is missing.
Old Dec 27, 2016 | 12:32 PM
  #67
AllGoNShow's Avatar
AllGoNShow
I have no PDM/DDM modules to view and modify Might go plug into my brothers '15 150 and see how many options they can view vs. the '17 SD
EDIT** Just pulled up As Built data on Ford's website;
https://www.motorcraftservice.com/AsBuilt/Details
And it looks like hopefully there will be more modules as updates come out! I am seeing a lot of modules listed that I don't see on the FORscan programming screen yet.
Old Dec 27, 2016 | 03:25 PM
  #68
Xwild's Avatar
Xwild
Confirmed the heated/cooled seats and wheel icons on the Sync screen with Sync 3 v2. That's on a 250 gasser lariate ultimate. Did have to say yes when it claimed a checksum error.
Old Dec 27, 2016 | 05:42 PM
  #69
AllGoNShow's Avatar
AllGoNShow
yes forgot to input the checksum value change as well.
Here is another from the Fusion sheet;
Fog Light Switchback w/Blinker:
726-28-02 (2014+ MY) xxxx xXxx xxxx
(BdyCM) 0 (Default Operation - Fog Lights Constant)
1 (Fog Lights Switchback w/Blinker)
Works for me.
EDIT: Another;
Disable Door Lock Horn Honk (2x Press on Fob)
726-38-02 (2014+ MY) xxxX xxxx xxxx
Note: This is great to disable horn honk with 3x Lock Remote Starters
(BdyCM) 1 (Enabled - Default)
0 (Disabled)
Old Dec 27, 2016 | 05:47 PM
  #70
AllGoNShow's Avatar
AllGoNShow
This one is super handy! Appears to work as well;
SecureIdle (Police Option):
Note: Doesn't Allow Vehicle To Shift From Park To Drive Without Passive Key Inside Vehicle (Shifter Locked w/No Key Detected Message)
726-42-01 (2014+ MY) xXxx xxxx xxxx
(BdyCM) 0 (Disabled - Default)
1 (Enabled)
Old Dec 27, 2016 | 06:18 PM
  #71
Xwild's Avatar
Xwild
What does Fog Light Switchback w/Blinker do?
Old Dec 27, 2016 | 06:21 PM
  #72
AllGoNShow's Avatar
AllGoNShow
Not sure on Halogen but for the LED's and in the aftermarket the switch back kills the white light (fog for us) for the turn signal amber, then 'switchback' the fogs back on when signal is done.
Function, video after with the Chev is a little better.
Old Dec 27, 2016 | 06:36 PM
  #73
AllGoNShow's Avatar
AllGoNShow
How do you like the 4.30 gears locked in the smaller 250 Ted? Interesting combo!
Old Dec 27, 2016 | 07:01 PM
  #74
EpicCowlick
This is great work. Our list of confirmed features just jumped to 7! I like the method of noting only the bit to modify in the form of xx1x xxxx xxxx. This simplifies the entry greatly. I think we are recording all necessary data but as always, anyone can report errors or request that additional information be tracked. The spreadsheet is a little Spartan right now but we can create additional tabs/workbooks as the list grows. For now each feature is entered sequentially as reported in the thread.
Old Dec 27, 2016 | 07:09 PM
  #75
EpicCowlick
Originally Posted by AllGoNShow
Hey Epic,
Not clear on this. Are you asking for the model/configuration to be recorded as an additional column?
