2017-2019 Super Duty FORScan Spreadsheet
#3631
#3632
The first time I made a bunch of changes using forscan my remote start stopped working. After a few days it just started working again on its own. Others have had a similar experience.
#3633
Try pulling the battery or batteries and let it sit for a couple minutes. Should fix it. I had this issue after making some changes
#3634
#3635
on
The only time I had it was when the battery voltage in my truck was low. I had left my Lights in auto. They were on because it was dark enough were I was working to activate them. I disconnected my laptop, took the switch out of auto, ran the truck for 10 minutes, tried it again and had no issues.
The other thing to do is verify your changes are correct.
#3637
#3638
Using the ELMconfig wired adapter with the HS/MS switch. ELM327 version 1.4
FORScan version 2.3.7
#3641
Added the ACC but have a code I can not clear. I was able to successfully do the CCM calibration but I still have 1 code and it is preventing the ACC from working. I can use the cruise just not the adaptive.
Code: U3002 - Vehicle Identification Number
Additional Fault Symptom:
- Signal Compare Failure
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Cruise-Control Module
Status:
#3643
Looking for ideas.....
Did the Global Window Open/Close a while back. Worked great. Haven't changed anything since.
Haven't used it in a while, now that the temps are climbing I used it the other day to get the heat out while walking to the truck across a parking lot.
Worked great until I tried the Close part later. Only the passenger side went up.
Closed both windows with the door switches and tried again. Both down, passenger only up.
Ideas?
Ideas?
#3645
