2017-2019 Super Duty FORScan Spreadsheet
#3271
New to the F150 community and definitely for sure new to the whole Forscan application and usage.
I was just wondering is there anything special you need to change and do for this to work on a 2018 F150 3.5L ecoboost or not really?
Did not know if codes or parameters or datasets are different based on the vehicle, etc or if it is just get the OBDII dongle, register on the forum, and download software get ID, etc and then you are good to go. Or if there was more to it than just that.
Thanks
Thanks
#3272
Thanks
Thanks
#3273
#3274
https://www.f150forum.com/f118/forsc...-truck-348987/
and
https://docs.google.com/document/d/1...gF1wxIqxY/edit
#3275
Received 6,718 Likes
on
#3276
Yes, that has already been established. I guess my statement was not abundantly clear to some, so please allow me to rephrase; Knowing it is an on/off switch, I still prefer it operated like a real pressure gauge. You know, where the needle fluctuates up and down (or back and forth) as the pressure changes ... I'd rather have that. Even a digital display of the oil pressure in pounds per square inch would suffice. The existing on/off gauge is sort of misleading ... and besides, 5 PSI ain't much.
#3277
Went well, but....
Backed up modules and made changes. Everything but the double honk worked.
But I didn't notice for a few days that my Sirius Travel Links no longer work. I get "Not available": on subscription info screen.
Oh and now I get an announcement every time I start the truck that I have chosen English.
Any Ideas about these things. I tried Sirius but they were no help.
TIA
TIA
#3278
on
TIA
TIA
#3279
Everything you ever wanted to know about Forscan and an F150.
and
and
To funny that made me laugh, nice.
#3280
#3281
TIA
TIA
#3282
Did you enable the "read texts/enable nav typing while driving" change in your APIM? If so this is likely to have caused those issues. Do you notice a different shape speed limit icon in the Nav screen? Are your radio station frequencies showing multiple decimal places? Basically it changes your APIM to the U.K. settings
#3283
Yes and that is exactly what happened! Changed back and everything works. But I would like to have nav unlocked so passenger can use it.
#3284
Because of the issues noted, I plan to leave my nav-system alone until such time someone identifies suitable (read that as trouble-free) codes. Please excuse me if I'm touching on plowed ground, but what is so wrong or difficult with using the voice-activated navigation?
#3285
Just in case no one has posted this info, you can use a mac laptop to edit with ForScan. You will need to use Parallels or VM Ware to run a copy of Windows within the virtual machine window and you will need to tell Windows to use Bluetooth on the mac laptop. I use a MacBook pro with the latest High Sierra OS and Parallels running Windows 10. Forscan works great in this setup.
