2017-2019 Super Duty FORScan Spreadsheet
#211
I found this today:
BCM: 726-26-02 x1xx xxxx xxxx - Parking lamps on with low beams for DRL
** Note I tested this using Canadian forced DRL settings because with my switch in the Auto position using U.S. settings and "daytime lights" selected in IPC, it was dark & rainy so the truck thought they needed to be on regarless of whether daytime lights was selected or not. So this needs testing with U.S. settings to see if it works as described.
I also updated my APIM spreadsheet here: https://docs.google.com/spreadsheets...gid=1479139836
#213
on
I can confirm the Global Window Open/Close setting work, but the only operate (open/close) the front drivers and front passengers windows. You must also be outside the vehicle to test this out.
Currently I have activated:
Double Horn Honk Disable
Fog Lights with High Beam LED
Heated and Cooled Seats Icons on Home and Climate Screens (mine was set to 4 (platinum) but I did not see the heated steering wheel. Note I have not tested it out yet)
Secure Idle
Its nice to finally have my OBD2 module back so that I could try these out!
Secure Idle
I found this today:
#214
I've tried a few more - no success on these for me:
Auto Fold
Auto Reverse/Tilt
Auto Re-lock
PowerPoint
Autofold Mirrors
DDM 740-03-01 x8xx xx
DDM 740-12-01 Fxxx
PDM 741-03-01 x8xx xx
PDM 741-12-01 Fxxx
Reverse Tilt Mirrors
DDM 740-03-01 Fxxx xx
DDM 740-13-01 Fxxx
PDM 741-03-01 Fxxx xx
PDM 741-13-01 Fxxx
Auto Relock enable
BCM 726-15-02 0101 0101 0145
Powerpoint timeout disabled
BCM 726-39-01 1194 0001 000D
Powerpoint timeout enabled & set to 1 second
BCM 726-39-01 0001 0101 006A
Auto Fold
Auto Reverse/Tilt
Auto Re-lock
PowerPoint
Autofold Mirrors
DDM 740-12-01 Fxxx
PDM 741-12-01 Fxxx
DDM 740-13-01 Fxxx
PDM 741-13-01 Fxxx
Auto Relock enable
#215
I found this today:
#217
#219
#220
7D0-01-01 *xxx xxxx xxxx Removes Sirius from audio sources (decrement your value where the asterisk is by 2; if you have an "A" make it "8", if you have "2" make it "0")
I can confirm that this did NOT work with Sync 3 ver 2.0. Its a shame. Hopefully Livintup can find me the right value. I hate having Sirius in the options for when I accidentally hit that M button on the steering wheel.
#221
#222
I'm not sure & I don't have anything to test it with like another camera. Here's the other issue that comes into play...with a 360 degree camera setup the truck uses the IPMB module to feed the video signals to APIM but a truck with say reverse camera only wouldn't have the IPMB and that would feed directly into the APIM. I've also never looked at the back of my APIM to see if there's an unused video input. There were some additional settings I saw in my new software program for APIM about video so I'll try and gather info on that as well.
#223
It didn't take effect right away but I turned truck off, open/shut door for accessory timeout to be cancelled, waited 30 seconds and turned back on and it was gone. I have the Sony system so not sure if this matters or not.
#224
I don't have the 360 camera setup. The harness should be at the front grill for the front camera.
If I knew the pin out, maybe I could hook my trailer's reverse camera there. But I'm sure there would be something to turn on in the module.
From what I've read the front cam has the ability to stay on while driving.
I'm trying to hook up my 5vers backup cam, but I want it to stay on while driving.
I was in the process of adding another screen...don't really want to do that.
#225
I take this back LOL...just tried it again and this removed Sirius from my sources: 7D0-01-01 8xxx xxxx xxxx
