2017-2019 Super Duty FORScan Spreadsheet
#182
Also found the following today if anyone wants to test for your spreadsheet:
BCM:
726-08-01 x1xx xxxx xxxx Tire Pressure Monitor enabled
726-08-01 x0xx xxxx xxxx Tire Pressure Monitor disabled
HSWM: (timeouts for HSW)
714-01-01 1xxx xxxx xx Timeout disabled
714-01-01 8xxx xxxx xx Timeout enabled, 5 mins
714-01-01 9xxx xxxx xx Timeout enabled, 10 mins
714-01-01 Axxx xxxx xx Timeout enabled, 12 mins
714-01-01 Bxxx xxxx xx Timeout enabled, 15 mins
714-01-01 Cxxx xxxx xx Timeout enabled, 18 mins
714-01-01 Dxxx xxxx xx Timeout enabled, 20 mins
714-01-01 Exxx xxxx xx Timeout enabled, 25 mins
714-01-01 Fxxx xxxx xx Timeout enabled, 30 mins
BCM:
#183
Lol, it's Heated Steering Wheel Module but from what Rebelz says I guess you guys don't have that?
#184
#190
I'll try to check today as I need to change a few other settings as well.
Full Disclosure: I feel like I'm all thumbs when using Forscan. I'm just not used to it yet. Although I've hacked just about anything I can get my hands on over the last 20+ years, I'm pretty nervous about bricking an $80,000 truck. lol
-ysgi
-ysgi
#191
-ysgi
-ysgi
#192
Well I dont know exactly what Ford considers to be cold climate but today the remote start turned on heated steering wheel and seat so I know the setting is somewhere between 46 and 36 degrees.
#193
ohhh.. that sounds awesome
I saw on the 150 forum that you said you don't want to link to it now because they don't have these in their database and it's trial and error right now.
Is it possible to get a link to it in the future?
also if you don't mind me asking what was the cost on it?
Sorry I'm just curious lol.
#194
#195
Yeah I'll link to it in the future and it was about $300 delivered. Unless you plan on flashing different firmware to your modules it won't be of much use by then. I'm working on mapping out all of Sync 3 APIM this weekend and will be replacing the current spreadsheet I have up with a new one that should show every function of every bit of every address. So once done with APIM, I'll move on to a different module and so on...
