2017-2019 Super Duty FORScan Spreadsheet
#1801
If anyone here is in the process of adding Adaptive Cruise Control to their trucks, I have a new test beta from the FORScan devs that includes the Cruise Control Calibration service procedure built-in. Normally, guys doing this mod would need the dealership (or someone with IDS) to carry out this final step but if anyone needs this, pm me and I'll give you a link.
#1802
#1803
Got a chance to work with forscan a bit today, added dpf% to screen info and enabled Bambi mode, but when it came to displaying temps agave gauges replacing EA with E5, A5, or 65 as listed on the spreadsheet wouldn't work. Never could get it to write the new value is there anything else that has to be done? Everything else I tried worked great but changing the 720-07-01 line failed every time.
Also on the Winblows side of things is there any way to get it to display gauges like the iOS apps or is it dynamic text only?
#1804
Can you post a pic of this service procedure in IDS because I own IDS and haven't seen anything except the calibration procedure. I'm curious what IDS shows when connected to a '17 SD
#1806
#1807
on
#1808
#1810
Don't run the OBDLink software that came with the adapter when trying to use FORScan, this will cause the "No ELM found" message...you can't have 2 different software apps trying to use the adapter at the same time. If the adapter is paired correctly you should see the adapter's MAC address showing in FORScan settings, connection tab like below:
Now I'm to my next hurdles. I didn't see, or save my extended license properly. When I go back through the Forscan process to "Generate", I get "License key with such Hardware ID already exists". On my PC, I can download it, but not open it.
Any suggestions?
#1811
7D0-03-01 xxxx x2xx xxxx
OR
7D0-01-02 8xxx xxxx xxxx
7D0-03-01 xxxx x3xx xxxx
#1812
#1813
#1814
Or it could be one extra value we need to change in forscan I am not sure.
