Emissions delete 1991 F-150 with 300 I6
Old 10-25-2016, 07:38 PM
enrgizerbunny's Avatar
enrgizerbunny
enrgizerbunny is offline
My truck went in for inspection this month. It failed because the injection manifold (that is part of the EGR system?) is broken and therefore leaking exhaust. Is there a guide on here to delete the entire EGR/emissions system? I don't have smog inspections and don't much care about fuel economy...
Old 10-25-2016, 08:25 PM
Harte3's Avatar
Harte3
Harte3 is offline
You don't have inspections but you had it inspected...?
Old 10-25-2016, 08:36 PM
enrgizerbunny
I don't have a SMOG inspection. But you can't have an exhaust leak before it gets behind the passenger area. The shop quoted $800 to replace, parts are about half that. If I were to do it I'd want to delete the system and just continue to get the 15 mpg I've been getting since the check engine light came on for "EGR reduced flow"
Old 11-09-2016, 09:16 PM
IsaacCarlson's Avatar
IsaacCarlson
IsaacCarlson is offline
I disabled the emissions on my '91 300 a while ago. A simple block off plate for the egr, removing the solenoids for the stuff i didn't want, and unplugging the idle control with any neccessary adjustment of the idle screw is all i did. The smog pump is long gone btw.
Bulldawg1081
03-10-2013 11:55 AM
Boss300
05-05-2010 07:23 AM
coreye1976
03-31-2009 11:06 AM
quadzjr
15
12-08-2005 04:36 PM
Quick Reply: Emissions delete 1991 F-150 with 300 I6
