So I blew a head gasket
Old 10-22-2016, 03:48 PM
yardape1's Avatar
yardape1
yardape1 is offline
So a head gasket on my 64 F100 with a 292 finally went. Any tips for replacing them, other than getting a manual?
Old 10-22-2016, 07:45 PM
66v8baby's Avatar
66v8baby
66v8baby is offline
I can't give specific Y block tips, but any time you blow a head gasket you need to have the head resurfaced. While it's at the machine shop have the valve guides checked for wear. You may also want to do a valve job while it's off. I would also consider doing both sides. Whatever caused one side to fail could eventually cause the other side to fail.
Old 10-23-2016, 09:07 PM
fivestarmmd's Avatar
fivestarmmd
fivestarmmd is offline
Its possible last person in it put the 2 long headbolts in middle instead of on ends. Be fore warned there is 3 lengths of head bolts used.
Old 10-24-2016, 04:22 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
It's pretty much the same procedure as any other engine. If you are generally familiar with that, then you don't absolutely need a manual. I still advise that you get one so that you will have answers to many questions right in your hands.
If you aren't familiar with that general procedure, then you need a manual.
As mentioned, watch out for the bolts. There will be either 2 or 3 lengths. Your truck is 52 years old so we will not assume that it is correct and prepare you for both. Earlier Ys only had 2 lengths and should be quite obvious where they go. Later ones had 3 lengths, 5 short, 3 long and 2 which are 1/4" longer. The 2 longest ones go at the very ends of the head, in the holes that have the dowels.
You do need to make an effort to determine why the gasket blew so that you're not doing this job again soon.
1990-f250
03-13-2021 04:44 PM
dairydude
03-13-2019 09:46 AM
RoyalFord
1997 - 2003 F150
03-30-2011 10:48 PM
ballyhoo
03-18-2008 09:04 PM
rsmack
05-11-2003 09:51 AM
Quick Reply: So I blew a head gasket
