October ghouls ghost story thread
#256
How does erratic idle speed help one discover yet another coolant leak?
Simple. When one misroutes the throttle position sensor connector too close to the exhaust pipe for the EGR, it tends to melt. When it gets wet from the coolant leak, it shorts out and sets the idle control valve to wide open. I found the bad connector which lead me to a pinhole leak in a coolant by-pass line.
I had a spare TPS connector which I wired up (and then rewired because someone forgot that signal return means ground) and replaced the hose. Hopefully that is the last of the leaks.
I think this job would have been much easier if I hadn't been pretending I didn't have a sinus infection coming on. Too many silly mistakes...
#258
#259
good evening all... i went to the shop today, but jeff had to work so i played with my black bronco a little bit.. i got the old trans out, measured everything to see what all i will have to change to install the C6 trans.. there is a little more to change around than i first thought ( isn't that always true) but all in all it should not be a real hard job.. i did get the trans and transfer case back in the truck and a couple of bell housing bolts put in to keep it from falling out..... i forgot to get the right side exhaust manifold replaced before i replaced the trans so i better do that before i get too much more installed.. i hope to make a lot of progress tomorrow..
#260
#261
dave the trans in it is the AOD with the cable. the only electronics on it are the speed sensor which i think will work ok in the C6.. the other wires are for the electronic transfer case on/off and high low.. i dont think they would even have any senders going to the computer.. i guess i will have to wait and see
#262
#263
#264
#265
#266
#267
#269
#270
